Hostile, that would be me! Where were you hiding?!
Hahaha I was stealth in my mums cough... volvo, so you would not have seen me!!
Reckon I saw you on south rd O'halloran hill on sunday mornin' too!
spotted a white r33 gtst, with a sau sticker on the back.... had black bonnet and black rims and boxing gloves hanging from the mirror, spotted in colinswood.
also kahli on the freeway this morning i think??? or atleast a look alike
just few mins ago, black 32 with some sorta kit - vertex i think.. didnt get a good look, black centered rims, turning down sidestreet off south road, mile end area. Seemed to recognise my car/plates.
Yeah that was me looked at the car then the plates and it clicked but was to late to wave at that point. My bad sorry
spotted aahh31 cruising in a hotrod over holdenhill way nice :laugh: but a trade down from the r31
yeah that was me in my old boys 32 roadster :rant: ... very tuff car :spank: . noticed a few envious glares from a few lines on montague rd then grand junction and nth east roads about 3.30- 4 pm today :P not a trade down at all but , that car has bigger balls than mine
I thought it was you, i just couldnt remember the username! I knew the car looked familiar.
Spotted last night a 4 door series 2 r33 skyline. Silver. Ps. Big SAU sticker on the rear window down penginton way...
If your on here i know u saw me give u the thumbs up lol!! totally ignore me! i was in the gtr
Spotted Heslo at Villi's the other night!! It's looking good since the crash Luke. I flashed my highbeams when you were leaving.
Also spotted a Maroon R32 GTR parked down the bay, Then saw him again while getting into my car, was gonna follow to do a bay run with him but had to get back to school but then as i walked in my lesson it went flying past my school!! WOW! Fast gtr.. :)
Edited by Lil Miss 32
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
