Spotted possibly 'sapphiregraphics' today, going up Elizabeth road, same white 34 with white rims and a sunroof i saw today.. forget the time, between 11 and 1 lol
yep that was me.. spotted a white r33 behind me when I turned from beach rd but it headed straight towards the sea
where were you hiding ????
spotted the white s2 stag with Mikes front bits on it (rsvaero or something) i changed lanes, flashed and waved hand out window but he must be BLIND
Spotted him again this morning going thru britania round a bout about quarter to 10am
spotted mycef3 and silver stag, black 200 with sinergy sticker on the back window at Hallet cove pub last night
+1 on that spot
spotted MUDHNTR on Lonsdale rd on the weekend
i reckon you might have seen my car (stupid looking yellow onevia)
- Craig
yeah, remember seein a yellow onevia on my travels
Yeah i was down that way leaving work around that time... Soo it might of been me!
Only thing is i dont remember seeing you :down: Probly was in my own little world as usual!
Im guessing u work down that way as well?
umm i sold my 32 :P
so i was in a stock magna lol you wouldn't have taken any notice of it i live that way was just coming home from colonnades
Nice, you drive past my house, up from the park.. saw ya heading back the other way too around 2ish lol know its you now so if i see you drive past while im out the front, ill wave..
Spotted a sweet ass black 32 on my drive home from work tonight.
Was on South Road Bedford Park headin south.
Gave a look and a nod, but I think he thought I was a weirdo lol
Edited by James34
spotted this in Guangzhou (china) a couple of weeks ago, only skyline to be seen in the 3 and 1/2 weeks I was there. The owner seemed very happy to have a westerner take a photo of his car. :)
After driving a 2009 Toyota Crown over there I dont think my next will be a nissan :down:
spotted a maroon 32 and a midnight purple 33 gtr on marion rd at about 5pm near the church thing
also tonight around 9 saw a black 33 with white wheels turning onto anzac hwy from marion rd
if it's the church thing I think your T
talking about, I live like 5sec up Marion road.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
