Modifying Stock R33 Airbox/snorkel Or Entirely Custom
I want to keep my intake similar to the stock setup (ie enclosed, fed from the front of the engine bay) but I don't want a pod. I hate the noise, and want to avoid the legal ramifications.
I've seen some made for V8/LS1 engines which look like I want.. big wide open mouth taking up as much space as possible where the bonnet meets the chassis, kinda like the stock air snorkel but much larger opening at the front. I'd also like to modify how the snorkel feeds into the airbox - if I've made the changes just explained, the join into the airbox will be the next bottleneck.
I'm going to buy a spare snorkel/top half of the aribox. Can someone tell me what I need to make these changes? I've heard of plastic welding... do I need to do that?
Thanks for any help in advance. Also open to going completely custom if I can get the materials and the know-how to do it fromt scratch, but would prefer to use the stock box and modify it, cos then at least it will look stock-ish. I'd like to use the same kind of material at the very least.
I also spoke to a (/the) dude that was going to do that a while ago ;) From memory, he ended up going pod lol
That's pretty much what I'd like to do though. I just realised a mate has done fibreglass work for audio installs - going to see if he can make something. And yeah: I want it looking like stock. Matt black and boring!
Edited by sl33py
Will do! Mate says it'll take a few days.
But from previous reading, I think the GTR intake is better than the GTST... It's larger. In fact, I think the intake I end up with could look very similar to the stock GTR one. Anyway, we'll see.
The primary reason a GTR33 airbox has so much potential is there is an extra inlet to the airbox through the side inner guard. Mine currently makes 320rwkw on the stock airbox and I'll soon push that over 400rwkw. It can't be done the same with a stock RB25 box, but I've seen a large improvement in simply removing the top out of the airbox on the auto 33 I had and sealing it to allow frontal airfeed only. Unfortunately the lower area of the airbox is not particularly good so on my race car (33 GTS25t with RB26/30) I custom made the new airbox to be where the stock cooler is with a stock panel filter in the front, bellmouth pickup inside and a vented front on the bumper will follow to allow direct air intake.
Great idea, worth the effort. With a high flow panel filter and this Julia Roberts mouth drawing in air you'll be able to drastically minimise restriction without getting a defect.
Cool geoff. I think I saw a picture of that. Changing the filter must be a hassle though? So far I'm just thinking of modifying the top section of the airbox and the snorkel. Also... I'm not keen on having the air filter so low to the ground. I'm in Canberra lol In Brissie and on a race car I'm sure it's fine though!
Edited by sl33py
I lived in Canberra for 5 years. I'd have it the same there but yes it is a race car, and I intend to make filter changes easier by making a louvered front panel held on with dzus fasteners http://www.my105.com/catalogue.asp?id=4558 or the like.
Pods though are not as good as people think.
I've used HKS pods and they let a lot of muck through in some designs plus filter poorly. A mate just had a turbo destroyed by a Blitz that let gravel in where he mounted it. About the only foolproof ones are Apexi and even then without a topnotch enclosure they are subject to too much hot air. Calculate how much air is taken in in eack cycle of the engine, then times that by RPM then wonder how much enters every minute. Compare that to the size of the engine bay and no surprise they will be sucking a massive amount of hot air.
I hate pods, but I'm only an engineer specialising in race setups and weapons systems.......
Read my original post ACTIVE32. Thanks anyway.
heheheh Geoff :P I'd be worried about the filter getting soaked when it p1sses down.. Mine's a daily driver.
One thing that came up yesterday - my mechanic said if I'm going to experiment with modifying the top half of the airbox and the snorkel, I don't need to get it retuned or anything afterwards. I asked cos I'm getting a new turbo (HKS GTRS) and all the other bits at once and want it all perfect.
If I muck about after the tune, will it be like when you add a better exhaust and don't do anything to the ECU - it'll adjust automatically to make use of the better flow (by extrapolation with load point data and using the AFM I guess)?
Adz, I found the pics here: http://www.skylinesaustralia.com/forums/Ai...gtrgeoff+filter post #14.
Edited by sl33py
Definitely interested to see what your mate comes up with...I'm interested in something like the pics I posted.
As for tuning, I had my car dynoed at my workshop in normal trim, and then straight after with the top of the airbox removed. There was a change in afr and some knocking, so to run like that it would have needed the tune adjusted.
Woah... You're tune must have been cutting it close WRT fuel supply? I sort of expect the engine should have room to move (supply more fuel) if a mod like this is done to supply (what probably isn't a whole lot) more air, and to supply the extra fuel needed. Hmmm. I guess it would depend on how much room there is in the tune and how much more the fuel pump and injectors can give.
Would depend on how "on the limit" it was the start off with too.
I wouldn't have thought a air box mod would change fuel requirements all that much, alas agree with you. Get it tuned after all your mods are done.
OK, well after about 3 hours of bvggering about with cardboard and getting nowhere, I've come to the conclusion that it's probably easier to get hold of a spare airbox and snorkel and modify them, if only to come up with a mold to make fibreglass copies.
Anyone think a soldering iron with digital control which can go up to ~300 deg C would do the job of a plastic welder? And anyone think that plastic plumbing pipe would work to make an airbox? If not, maybe I'll just make a mold using it. What I'm really after is a material easy enough to work with that I can easily make a mold out of, or cheap and sturdy enough that I can actually make a permanent airbox out from. Gonna go look at Bunnings etc this morning.
Edited by sl33py
i used a cheapie direct plug in soldering iron to plastic weld, so that adjustable one will work.
you'll need to try and get a hold of some filler rod for the plastic welding .. or use off cuts as filler.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
