  • Replies 64
Hehe it's all good, I know you two are playing (love you too Noel)
So keep arguing or I'll ban you both :P
Wait wait.. I don't want to get banned so just to clarify.
you want me and the grumpy bastard to argue against you right?
call you names and rumours about your mother?
is that right?
Keep your fantasies to yourself Daz lol
And I'm sure you guys will be ecstatic to hear that I have let my hair grow a bit... right next to the bald patches :yes:
So we can expect the "convertible" look now depending on which way the wind is blowing? :D
