Hiya Everyone,
I have just noticed recently that I have a fairly substantial amount of rust in my rear wheel arch.....
My questions to everyone are firstly is anyone else experiencing any rust in their skylines yet???
Secondly I need some advice on where I can get this cut out??? I posted in the panel beater thread already but I would like more of a response as I want to chase up some prices from places this weekend....
So post any problems you have had with rust in your skylines and please let me know of any good places to take my car to get it cut out...
Thanks
Brett
https://www.sau.com.au/forums/topic/20646-rust/
Brett - I'm not sure of a place to get it cut out, but there is this stuff you can buy which converts the rust back to metal and stops further rust forming in the area. You have to rub it back with a wire brush or something the apply this. I will try and get the name of it from my dad... but I'm sure of you ask at hardware store, they could help
https://www.sau.com.au/forums/topic/20646-rust/#findComment-433616
Hi Guys. I was brought up in the land of the rusty car, the UK, and I have fought many long battles with the stuff on various cars, including a beautiful 260Z, which dropped to bits around me. So I can tell you that the only way to cure it is to cut it out and replace it with good metal. All of these things that claim to convert rust back to good metal are crap. I know 'coz I spent hundreds on them!! And I diligently brushed and painted and coated even beyond their expectations - and it still didn't bloody work!
I know the UK is a harsher climate than sunny WA, but if the stuff has set in you will be very fortunate indeed if such a surface treatment will be effective. Theoretically they should work, but in practice they never do.
Just don't spend too much time by the ocean on windy days!
Cheers.
https://www.sau.com.au/forums/topic/20646-rust/#findComment-434358
Firstly thanks for the responses so far :(
The rust seems to have worked its way all the way around the wheel arch..... in most places it is just bubbling under the paint but for about 10cm's it has actually broken open and you can see the crack in the metal....
My car is always garaged and taken very good care off.... But then again I don't know the life it has had in Japan..... Mechanically my car is very sound, but I am getting a little rust.... I suppose thats the risk you take when importing cars :)
I will look into all options but I would still be more comfortable in having it cut out so I know its gone for sure....
Keep those replies comming ;)
https://www.sau.com.au/forums/topic/20646-rust/#findComment-434644
The reason for it will be that it's had a replacement 1/4 panel and the Jap beaters don't reprepare the join properly , hence water and dirt gets trapped between the inner and outer skin.
Only way is to get it professionally cut out ( not bogged ) and repainted.
Cheers
Ken
https://www.sau.com.au/forums/topic/20646-rust/#findComment-434723
That's what I thought ( In terms of cutting it out ) .... any recommendations of quality workshops? I plan to go around to a few places this saturday morning to get some quotes and I want to make sure I am visiting the right places..... PM's will also be welcome if name dropping on a public forum is a concern...
Thanks
Brett
https://www.sau.com.au/forums/topic/20646-rust/#findComment-435037
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
