Aight,
My coooling fan clutch is officially shagged. It had a good life. Now the fan is really noisy all thru the rev range (sounds like an old VB commo now! ugh!)
The fan no longer spins freely with the engine off... hmmm... ahwell.
Anyone know where I can get a new clutch pack for these things in perth ? How much am I looking at ?
Or can I repack the bearings and not spend much cash on this stoopid thing?
What about a thermo-electric fan, how much are these suckers goin for ? DIY install ?
-Kym
https://www.sau.com.au/forums/topic/20656-fan-clutch-is-rooted/
Go for an electric fan, for sure. I'm just waiting for mine to die so I can convert :P.
Davies-Craig have a few but they cost dollars (~$300). Could try seeing whats avaiable in 12-16" at the wreckers. DIY install is possible; try a search cos a few ppl have done it.
Kym,
I'm not sure - but if the fan is anything like the ones on the RB30 engine - it hangs directly off the waterpump shaft. Your fan clutch not working if the fan is on the waterpump shaft is a bad thing - read again - a bad thing. If the fan is running all the time and stops when the engine stops this means that whatever bearings are holding the shaft are being put under alot more stress than normal.
Fix it quick or suffer the wrath of having to replace a waterpump..
Hmmm. That was going to be my next question cam, thanks for the heads up. I'd figure it'd be something like that.
All that extra stress on those parts can't be good.
Alright, I dont wanna spend loadsa cash on this project.... where can I get a new clutch pack for the fan on the cheap ?
Kym - again - if it's the same one as the RB30 (by now you should realise I'm not sure) then repco or marlows or any place like that should have one. I bought one a few years back for a VL and that was around $140.. Thermo may be cheaper in the end...
  • 2 months later...
GUYS! DO NOT FILL FAN CLUTCH WITH SALASTIC! It'll have the same effect as the current situation and will end up rooting your water pump very quickly - the fan hangs off the water pump shaft... ref - my first post in this thread... :D
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
