  • Replies 62
I really dont know how much to read into torque
This was my readout with standard everything really
it is an auto and in second gear i think that make abit of a difference with gear ratios etc ( not sure the exact ratio of 2nd compared to a manual in 3rd gear)
Hmm something dodge with that torque readout. Maybe some others more knowledge than I can explain how it could read that. Maybe the one above is also subject to discrepancy via how its measured... but stock doing 800Nm is a 'off' looking lol Also... you're power looks insanely high for a stock GTT/GTST type engine. Aren't dyno runs usually done in 4th or 3rd? Don't recall seeing one in 2nd before.
Maybe this is why my mechanic said he doesn't usually bother measuring torque cos it depends on the dyno setup too heavily? or how its used... or something
Ok yeah im sure that having the car in 2nd gear (not a 1:1 gear ratio) is going to affect the readout somewhat....
Time for a new dyno operator. Doing a dyno run in second is compeltely stupid. Auto's need to be locked into 3rd gear.
Your torque figure is all hot air, realistically, it will be a bit above 500nm.
I've got 720nm with 314rwkw in 4th gear, so if I did my car in second gear, I'd have about 1000nm...
And people wonder why I'm always questioning dyno readouts.. Especially those with a 30degree difference between their ambient and Intake temperatures...
oh, and this is a real curve, done in 4th gear..
Edited by The Mafia
I think my torque level takes a nice big dump on yours..[/quo
having your hand on it again as i see..
don't be blind have a look again 693 is not 700 and 844 is 844 and your afr is all over the place great tune.
mainline dynos do not lie .
Edited by WARLORD
hand isn't on anything, because how the hell could a smaller turbo make more torque than one significantly bigger?
It doesn't make sense at all.
Oh, and I compared my dyno to the other one done in second gear, not yours. BUt I still find it hard to believe that you are making 800nm from a GTRS - thats not correct. The turbo is simply too small to make that kind of torque.
There is something fishy about your dyno run -
* what gear was it in?
* I'm no expert at dyno settings, but ours are different, most likely why yours is higher.
* Do you have diff gears etc?
Something isn't right.
sorry for the last comment.about your hand, i thought it was for me .
yes its right is your engine full rebuilt with cams and pistons and rods and plenum ect ,if you have any questions on it ill give you the number of the guy who built my engine and you can call him.
this is a older dyno look at the afr if yours was a little like mine same boost you would make more power
Edited by WARLORD
well, this is how i see it - THe rods and pistons would make no difference at all to the figures, yours will just last longer.
The cams, well, you have cams, and I have water methanol injection.
So that would balance it out a fair bit.
Strange one this one.
What cams have you guys found to be the best for the GTRS setup? Tomei Poncams 256/256, HKS cams 256/256 or 256/264? Thinking about chucking the cams in a few months time. Just not sure on which ones to go, thinking about the Poncams.
Either that or MAJOR head mods required to fit; possibly also need to go solid lifters :thumbsup:
Hmmm i think i might stick to the poncams for the time being, don't think my wallet is going to like doing major headwork at the moment lol. I've done a bit of searching on whether the HKS 256/264 setup is better then say a Poncam 256/256 for my amount of mods, just everyone has so many different opinions on it. Obviously for a more extreme setup the larger cams would be good, just not sure for my setup what would give the best results.
i see your 1/4 mile time and you got a 114mile/hour, last time i went i got 118 mile/hour it with a bad start well a totally shit one really ,i happen to see 2rismo who thank god was trying to help me out and he was pretty sure that i should get a 11.8 but the rain came and that was the end of supernats .so back to what i said be for the car is what it is whether you want to believe it or not.also pistons are 20 thou over size reco head plenum ect don't know if it makes a difference on your scale of things!!!!!
at the end of the day this is all starting to be come a school quarrel over who has the better toy!!!
so if it makes you feel better you have the better toy !!
have a look if you want to .
http://www.skylinesaustralia.com/forums/Mo...tml&hl=gtrs
Just trying to find some answers. THis torque reading is fairly high, and imo too high for a GTRS so I am wondering why for a number of reasons:
1. Maybe I could replicate it on my setup
2. Maybe My setup is low on torque
3. Is the dyno reading incorrectly
Just a note - 118mph is a high trap speed. My mate with an XR6T ran 118mph with 310rwkw and 900nm.
Are you sure you're running 260rwkw or could you be higher, but the dyno actually read less?
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
