Hey guys, i was checking out some lambo doors, i found this site lambodoorkits.co.uk which have very decent pricing... It looks pretty good postage is £40. Anyway theres 2 different one's to get for my car, the more expensive one is the direct bolt-on kit and the other one is the universal kit which you have to get the doors welded.. Anyone know how much each would cost to get installed? Im thinking the direct bolt on wouldnt be so much considering it isnt being welded.. and they told me "The universals will lift to 90 degrees, whereas the direct bolt ons lift to 75-80 degrees".. I dont mind getting the more cheaper doors since i dont really plan to change the doors back to the original... just want to know how much each installation would cost.. anyone have any experience with this kinda thing?
Oh and more importantly anyone know anything about the door's legal wise? The last thing i need is another is a defect.
LDK Nissan Skyline R32 lambo door kit £450.00
http://www.lambodoorkits.co.uk/nissan-skyl...-door-p-60.html
Nissan Skyline R32 90 degree diablo lambo door kit £299.00
http://www.lambodoorkits.co.uk/nissan-skyl...oor-p-1888.html
Any comments would be appreciated..
Thanks
https://www.sau.com.au/forums/topic/206713-lambo-doors/
  • Replies 159
make sure you have some spare $$$ left on your mastercard cos they always end up costing a bomb to fit...
all sorts of fabrication req'd no matter how "bolt on" they say.
they are also heavy and a pain in the ass for daily's.
https://www.sau.com.au/forums/topic/206713-lambo-doors/#findComment-3662586
Disappearing doors are so cool! It'd cost a shit load more than scissor doors though!! I'd love to have scissor doors, they look fantastic and grab everyones attension. Isnt that why we have the Cosmetics and Styling section on the forum? I love them, and can't wait to get them. Altho, I might have to cut a hole in my garage roof to open them...
https://www.sau.com.au/forums/topic/206713-lambo-doors/#findComment-3668864
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
