Hi all, i was not sure where to post this ,i am looking to purchase a brand new HKS Super Power Flow Pod Filter and im looking for any places in Melbourne,Vic where they sell these for my R34 GTT i just purchased a Z32AFM from Just Jap and am looking for the Pod Filter to match, also can someone tell me which to recommend as i know there is a 150x80mm or a 200x80mm (what is the difference? ) bit of a newbie at this ,, any help is appreciated.
Thanks,
David.
https://www.sau.com.au/forums/topic/207276-hks-pod-filter-dealers-in-vic/
im sure there would be a business trader on sau that sell them, i bought mine from a trader(cant remember which one) just do a search in the classified section.
the difference is obviously the size. i guess more surface area = more intake
Edited by 33drifter
why do u want a HKS one???
i recently read that they were one of the worse performers both suction and filteration wise.
http://www.mkiv.com/techarticles/filters_test/2/index.html
Edited by R34NRG
u can buy em absolutely anywhere to answer ur question.
get a stainless steel Blitz 4" pod thats just me thoguh
Hi Andru, thanks for your response, to be quiet honost with you i just figured the HKS was the main filter to get besides the apexi, i had a HKS on my R33 and didnt bother looking into other options.
So you recomend the blitz4" pod, ,,does this straigth bolt onto the Z32 ,i was also considering the Apexi Pod filter (dry no oiled) from Access Auto in Vermont.I believe from the article you posted the Apexi is up there with the Blitz
thanks again for the info it was very helpful,
David
The apexi dry element filters are good, or the blitz one. HKS flows well, but because of the oil they can get a bit of gunk on the airflow meter. Oh, and don't believe everything you read on the internet :(
Thanks goes to FunkyMonkey for telling me about this airfilter;
Outright Winner of the
Ultimate Air Filter Shoot Out
1st in Flow - A huge 601.2 CFM!
3A Racing out - gunned Apexi, K&N, HKS, Trust & AEM
Article courtesy of Auto Salon Magazine,
Issue 51, January 2007
http://www.3aracing.com.au/HTML%20Folder/I...Shoot%20Out.pdf
Costs about $50~ including adaptor
Purchase from; http://www.australianauto.com.au/
Yeah I bought my tow hooks from AAA. Not many people seem to know about the place.
I got 2 HKS air pods on mine.
On The Run Motor Sports sell them. Speak to Jonny. He's the owner. I would think he still is, haven't seen him for a while.
http://www.ontherunmotorsports.com
137A Westall Road
Clayton South VIC 3169
+61 3 9547 8100
[email protected]
Edited by (00)SKYLINE(00)
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
