Hi Guys.
I promissed you some pictures of my little upgrade, here they are.
Today we will put on the Intercooler and pipes, airfilter, build a new 3" exhaust, and then i hope we can fire it up sunday.
Edited by Stagea Denmark
https://www.sau.com.au/forums/topic/207363-stagea-upgrade-with-dyno/
Hi Guys.
Today we will put on the Intercooler and pipes, airfilter, build a new 3" exhaust, and then i hope we can fie it up sunday.
Coming along nicely......be good to see it finished.....
Looking good! You're not wasting any time, are you? Post more pics as you go along: it is a lovely looking car, and you'll LOVE the manual!
Nope, i work on the car every day from 08.00 untill 18.00. :thumbsup:
All the piping to the Intercooler will be polished alu pipes, and the same for the pipe from turbo to airfilter.
I will post more pictures later today, right now it is 07 i the morning here in Denmark, and i will start working again at 8 o'clock.
When the car i finished, i will make a little video, and show you guys downunder, some danish smoke.
Thanks guys.
Here is a few extra pictures.
Cinter-metal clutch, Intercooler mounted, building pipes to intercooler.
OBS. Wrong airflow meter, just mounted to get the engine started.
Like I said: you're not wasting any time! Very impressive: when do you expect/hope to have it back on the road?? At this rate, it sounds like you'll only need another 45 minutes! :banana:
Hopefully in 2-3 days, then i will put it on the dyno at 0.6 bar, to see the output, the goal is 500+ whp at 1,2 bar, is that not possible, bigger turbine, injectors and another ECU.
What's the Stagea head-count in Denmark roughly? Are they everywhere or are they super rare?
Love what you're doing too. :D
This is the only one in Denmark, as far as i know, is there only 3-4 i Europe.
Thx, sound and more pictures will be posted tomorrow, forgot my camera at the workshop.
hows that for exclusivity... what are the rules for bringing a japanese import to denmark? ours are pretty strict, you cant just bring anything in, and when you do bring a car in, it costs about $3000 worth of work before the government says its safe to drive on our roads.
Maybe if our roads werent so shit it wouldnt be a problem.... [/rant]
When we import a car from Japan, we have to pay 180% in tax, on top of the price for the car, that really suxxxs.
Thats why we only have old cars in denmark.
I payed 45.000 AUD for for my Stag, with a RB25DE engine year 98, what will this car cost i Australia.!!
A BMW 320 new model, will cost 100.000 AUD, whats the price downunder.!!
The RB25DE is too shit to bring into Australia. You can only import the turbo models.
But for 45,000AUD you would get a full bombed off the dick 400awkw+ 260RS.
A base model 320i with no options here is about 55,000AUD + on road costs (registration, tax etc). Maybe 63,000AUD all up.
For 100,000AUD you buy like a 335i or similar.
wow you guys really get the short end of the stick.... I got change from 23k from start to finish including new tyres and rego and i have an immaculate 97 260RS.... (well i havent seen it yet but err yeah.... haha)
Hey guys.
It is up and running right now, it started firste time we turned the key, and it sounds like a million hp, i will think it have around 300-320 hp at 0.5 bars boost, i have tryed to upload a video at youtybe, but without luck, video vil be added later.
We have adjusted the ignition, fuel, airflow, and it have the right amoung off fuel, when we boost, or cruising, new Apexi ECU will be attached sone, and bigger injectors, bigger fuel-pump, the i hope for 550 hp at 1,2 bar, it shut be possible.
Is it possible to upload a video, 10,2 mb at this site.!!
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
