Hi Guys.
I promissed you some pictures of my little upgrade, here they are.
Today we will put on the Intercooler and pipes, airfilter, build a new 3" exhaust, and then i hope we can fire it up sunday.
Edited by Stagea Denmark
https://www.sau.com.au/forums/topic/207363-stagea-upgrade-with-dyno/
Hi Guys.
Today we will put on the Intercooler and pipes, airfilter, build a new 3" exhaust, and then i hope we can fie it up sunday.
Coming along nicely......be good to see it finished.....
Looking good! You're not wasting any time, are you? Post more pics as you go along: it is a lovely looking car, and you'll LOVE the manual!
Nope, i work on the car every day from 08.00 untill 18.00. :thumbsup:
All the piping to the Intercooler will be polished alu pipes, and the same for the pipe from turbo to airfilter.
I will post more pictures later today, right now it is 07 i the morning here in Denmark, and i will start working again at 8 o'clock.
When the car i finished, i will make a little video, and show you guys downunder, some danish smoke.
Thanks guys.
Here is a few extra pictures.
Cinter-metal clutch, Intercooler mounted, building pipes to intercooler.
OBS. Wrong airflow meter, just mounted to get the engine started.
Like I said: you're not wasting any time! Very impressive: when do you expect/hope to have it back on the road?? At this rate, it sounds like you'll only need another 45 minutes! :banana:
Hopefully in 2-3 days, then i will put it on the dyno at 0.6 bar, to see the output, the goal is 500+ whp at 1,2 bar, is that not possible, bigger turbine, injectors and another ECU.
What's the Stagea head-count in Denmark roughly? Are they everywhere or are they super rare?
Love what you're doing too. :D
This is the only one in Denmark, as far as i know, is there only 3-4 i Europe.
Thx, sound and more pictures will be posted tomorrow, forgot my camera at the workshop.
hows that for exclusivity... what are the rules for bringing a japanese import to denmark? ours are pretty strict, you cant just bring anything in, and when you do bring a car in, it costs about $3000 worth of work before the government says its safe to drive on our roads.
Maybe if our roads werent so shit it wouldnt be a problem.... [/rant]
When we import a car from Japan, we have to pay 180% in tax, on top of the price for the car, that really suxxxs.
Thats why we only have old cars in denmark.
I payed 45.000 AUD for for my Stag, with a RB25DE engine year 98, what will this car cost i Australia.!!
A BMW 320 new model, will cost 100.000 AUD, whats the price downunder.!!
The RB25DE is too shit to bring into Australia. You can only import the turbo models.
But for 45,000AUD you would get a full bombed off the dick 400awkw+ 260RS.
A base model 320i with no options here is about 55,000AUD + on road costs (registration, tax etc). Maybe 63,000AUD all up.
For 100,000AUD you buy like a 335i or similar.
wow you guys really get the short end of the stick.... I got change from 23k from start to finish including new tyres and rego and i have an immaculate 97 260RS.... (well i havent seen it yet but err yeah.... haha)
Hey guys.
It is up and running right now, it started firste time we turned the key, and it sounds like a million hp, i will think it have around 300-320 hp at 0.5 bars boost, i have tryed to upload a video at youtybe, but without luck, video vil be added later.
We have adjusted the ignition, fuel, airflow, and it have the right amoung off fuel, when we boost, or cruising, new Apexi ECU will be attached sone, and bigger injectors, bigger fuel-pump, the i hope for 550 hp at 1,2 bar, it shut be possible.
Is it possible to upload a video, 10,2 mb at this site.!!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
