Hey Guys
Just wondering when is the release for the evo x in australia, was in NZ and saw a few around are they out here yet. Also what price are they expected to be around. Wouldnt mind getting one well either that or a 34 GTR but will see. Want a R35 but dont think I can wait till the get realesed in australia or compliance gets happening.
https://www.sau.com.au/forums/topic/207399-evo-x/
Latest info I have seen is late March, early April. Looks to come in two variants, GSR and MR although the MR hasnt officially been named that in Oz yet.
Price wise $60K for the GSR and $70K for the MR. The MR includes some extra trickery like the MR version of the previous models such as Bilstein shocks etc.
https://www.sau.com.au/forums/topic/207399-evo-x/#findComment-3669542
Yes potentially there are some mechanical differeneces, article:
http://www.drive.com.au/Editorial/ArticleD...ArticleID=43984
A second model, which may be branded the Lancer Evolution MR - though Australian naming has yet to be finalised - will cost around $69,000. In addition to the GSR equipment list, the MR will add lighter Enkei alloy wheels (said to save 3.7kg overall), race-ready suspension (Eibach springs and Bilstein dampers) and a high-performance two-piece front brake disc.
Mitsubishi Australia is still putting the final touches on price and specification levels, so it's not known if both models will come standard with the five-speed manual transmission, or whether the higher spec MR will get the new TC-SST semi-automatic gearbox, complete with two computer-controlled clutches.
https://www.sau.com.au/forums/topic/207399-evo-x/#findComment-3670021
I went to the launch of the EvoX last year with Matt Lowth and a few others. Car looks pretty good. The MR is going to kick ass over the standard EvoX though. The interior is just so much nicer. DSG style shifting and paddle shifting is also very cool.
I think I posted some pics up in a thread awhile ago.
https://www.sau.com.au/forums/topic/207399-evo-x/#findComment-3671019
So u gonna get one Leewang?
Nah, not getting one. After looking at it more carefully, even though the interior is prettier and it's got more safety stuff, it's too heavy and I think a IX would still be a better car for our kind of usage.
For an all rounder though, the X MR will be an ace car.
https://www.sau.com.au/forums/topic/207399-evo-x/#findComment-3671458
Looks like the manual tranny is on its way out very soon... bring on the paddles :ninja:
https://www.sau.com.au/forums/topic/207399-evo-x/#findComment-3674507
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
