Well for those who wanted to know how the K5-660R with a dual exit 47mm blitz gate stacks up.... here you go. I am pretty happy with the results and it would be interesting to see how it directly compares to the T04Z with the equivalent 0.81 housing instead of the 0.61 it now has...
Remmeber we use it for drift so we are looking at low and mid range...top end is nearly useless to us so i choose two housings, the #7 (10cm ish) and a #9 (12cm ish)
This graph is running the smallest rear housing the #7... and 16psi, we will try the bigger housing after tassie just to run a back to back comparo on response differrences vs top end gain.. We are happy with the #7 housings response and peak power considering how low the boost is. I reckon with some cam timing adjustment it can be further improved on... atm engine is 100% stock internally apart from a 1.2mm head gasket which was already fitted when i bought the front cut.....
Peak torque @ 4200rpm
peak power @ 7000rpm
all run at 16psi.
Not bad, nice work!
Scuze for stupid question, but is the RPM scale accurate?
Stopped rev'ing before 8, is that done for preservation??
yeah the engine is a "kinder suprise" and has done well over 150k (NISMO dash in front cut so probaly closer to 250k) and a full DA season :( the limiter is set at 8000 but power increased only minimally from 7500-8000 so its tuned up to 8000rpm.. subsequently pulled the runs short to around 7200-7600 this run just happens to finish a bit earlier hence the pronounced drop off after 7000.
RPM scale is 100% accurate.
mmmm wheelspin on the dyno in the midrange sounds like fun times on the track then :( q
we did a circuit practice friday arvo at winton.... thing seems ok.. wednesday at calder will be the real test.
Any pictures of the wastegate off the car? Cool to see a different turbo being tried
just this one.
i will interesting to see it with the bigger housings, to compare with other twin setups. At the moment the thing is hardy working at 16psi either.
Cheers Trent, as a 26 single owner, ill be keeping an eye on your Nazi built single setup.
Makes the monkey on my shoulder sigh with some relief, knowing the K's Kats motor has done... hard K's too I would imagine :(
Scuze my ignorance, but what numbers was the setup doing with the Trust 517 (?) twins before?
Edited by GeeTR
all run at 16psi.
t04z @ 16.5psi 515rwhp
k5-660r @ 16 psi 415rwhp
blitz has a little bit more better response than t04z but 100rwhp is a lot more power, i think a 35r would be a better comparison
im with simon the comparison would be more along the lines of a gt3582r, my best mates rb26 made 440rwhp@ 18psi with an identical power and tractive effort curve to that last week (metal gasket,tomei pistons,head ported but std cams/no adg gears)
nice work Trent :)
Yeah but that is with a .82 on the to4z, the K5 is currentley running .6ish housing... with the .85 i have seen 560rwhp (418rwkw) quite easily with the #11 housing (using #7 atm) @ 1.3bar, i havent played with the big number 13 housing though, it it is very comparable.
nice work Trent :)
yeah ive used them alot, they are quite a bit smaller (61.3mm vs 65.5mm wheels) and not as responsive as the K5... similar top end per psi though (0.82), but the blitz is running a way smaller housing (0.6ish) to match the GT3582r's power which is quite impressive.... hence my intrigue to fit the big housing on the 'built engine' if this one ever expires :)
  • 1 month later...
ive made 585rwhp on 18psi with t04z 0.81 on a very very low reading dyno before (that dyno reads 45hp lower than brand new dyno dynamic dynos around here), motor isnt stock though so hard to compare back to back
Yeah but that is with a .82 on the to4z, the K5 is currentley running .6ish housing... with the .85 i have seen 560rwhp.
i under stand it is smaller and wont match it for out and out i just want to compare area under the graph... if it comes close to the top end but has more mid and low i know what to use on my next few builds instead of the To4Z...
just put the new built engine in too;
only a simple build..
ARP heads, mains, cam caps
H-Beam rods
GREDDY pistons (had JE but wasnt happy with crown design so used them in the spare eng :down: )
1.2mm GREDDY Head gasket
GIZZMO phenolic isolator intake gasket
King bearings
Greddy Oil pump
Tomei sump Baffle
1mm srew in Oil restrictor
-10 Head to Sump drain.
New valves, Buckets etc
GREDDY valve springs
New profile greddy procams only babies 264 IN / EX with small 9.7mm lift
Cam Gears
my new dynapack arrives next week so cant wait to wind her up a bit :P will do back t back with the 3 housings i have here :D
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
