  • Replies 128
Yep oblivion, i checked before buying that everything is in stock. So the turbo should be here probably monday i'm guessing (maybe tomorrow if im lucky).
I asked HPIAB and to my suprise they have a "real" GT3071R on the shelf ready to go... and yes it is "a 700177-23 core which allows an off the shelf .63 4 bolt" - to quote morrie. This matches up to the garret specs on http://www.turbobygarrett.com/turbobygarre...T30/GT3071R.htm so FINALLY i've bought it (and at a decent price).
Unfortunately, there's no place i know of in melbourne that does these at a decent price - not that i've looked all that hard as i've stuck mostly to online buying. An mate who actually works for Honeywell didn't give me a better price either. Getting them from America is cheap (especially with the current exchange rate) - but they take an absolute hammering during shipping (don't beleive anyone who says otherwise) so stick local!
what price are we talking about (PM me if u like)?
I got a pleasant surprise when i unwrapped my turbo. It is a genuine -23 cart :wave:
And unfortunately even with the garrett turbine housing and .5 A/R cover it still needs a spacer.
But the turbine housing is bollocksing massive! And it's only a .63. All i've dealt with for the last 2 years is my non gated .63 turbine housing and t28 sized ones. This thing is a monster!
edit: lol at the swear subsitution enabled on the forum :wave:
Edited by BHDave
The viewers at home would probably like some snaps of the ID tag and that 0.63 A/R GT30 IW turbine housing so they know one when they see one .
Cheers and thanks , A .
Apologies in advance for the quality of the pics. Low light and phone camera aren't a good combo. At least one of the 3 photos of the tag is partially legible....
Out of interest, does anyone know why garrett make the inlet smaller than a regular t3 size? As i have a spacer i'll be die grinding that to smooth the inlet into the turbo, but it just doesn't make sense to me.
oh yeah. manifold to turbo studs are 1.5 pitch where they screw into the manifold but 1.25 on the other end. just discovered that after buying new long 1.25 studs :thumbsup:
im not sure either BHDave, but i tired diegrinding the spacer and i was there for ages getting no where, i paid 20 bucks for a machinist shop to mill it out for me after i traced an outline of the real flange size onto it.
goddamnit! This was supposed to be easy! :thumbsup:
nah no problem putting it out there:
HPIAB: $1950 ($1750 for external gate)
CRD: $1920 ($1770 for the external wastegate)
APT: US$1449 + US$95 shipping + import duty + GST etc etc
FULL-RACE: US$1149 + all above (didn't reply to any emails).
Looked at ALOT of other places; most didn't have the "real" one, or didn't reply to my questions.
Like i said before, vary wary of overseas shipping of delicate items like a turbo - not only that, you have next to no protection if your stuff isn't right/ get ripped off etc etc.
Edited by -33-
BHDave I think the reason why the Nissan RB20/25 manifold flange is wider than GT30/35 turbine housings is because they are a split pulse design so probably more like a "Euro T4 twin scroll" housing flange pattern than single scroll T3 .
Brett Lloyd once told me that there is lots minor variation like this and another one is the larger T4 and T4 "International" which some call T45 .
Geoff Raicer (FullRace Geoff) had issues with some housings because they are large T4 twin scroll flange and stud holes but with T4 Euro twin inlets .
The problem seems to come from the fact that Garrett is not one company and different parts of it in different parts of the worlds made different things to suit themselves .
Once we start to mix n match different bits things like this are common .
Cheers A .
That actually makes sense when you look at the area of the outlet/inlet. If you allow for the center divider of the stock manifold it's be pretty close in effective area to the single scroll inlet of the new turbo.
An hour and a half, 1 grinding wheel and 4 beers later i managed to get the spacer flared out to match the gasket. It looks pretty good atm, i'll reassess when i'm sober :) Also did a trial fit, I need to reroute some wiring or i may have some issues when i hit the track and the housing gets warm. It's a pretty tight fit in an r32.
Picked it up today from the depot...
Its an authentic 3071R, code and compressor housing matches BHPDAVE's above (-5023)... but what's the exhaust housing??? Doesn't look the same!!! Its for ext. gate =(
Edited by -33-
haha nice work! yeah i moved my wiriong further up, then insulated with wrap. other then that tho it fits in there nicely!
definately. There's still more room around the turbo than i had with the old kit. It was also a novelty to be able to access 11 of the 12 manifold nuts with a socket from the top. It used to take me 2 hours of swearing and crawling under the car with an open ended spanner to get the old turbo and manifold on. this time it took me about half an hour. I still spent 2 hours reinstalling the bastard water hose that runs across the back of the head....
Intake pipe and hot pipe are just about sorted. just need to find a spot to fit the bov (stupid type R is too big to fit easily if you want it plumbed back). The front half of the front pipe is tacked up. Will be having a go with the wastegate pipe tonight before doing much more with it.
WELL, i just found out that AVO makes a 0.63 internally gated exhaust housing to suit the 3071, with an RB25 dump pattern... AND at the same price as a garret exhaust housing. I'm looking to put either the garret one (requires new dump) or the AVO one on my "real" 3071 (since i don't want the external gate).
Anyone had any experience, info on these??
it may or may not be similar to what i have, exceopt i doubt the AVO wont will cater for the full 60 mm wheel. I have a cropped 3071R with a GCG cast rear housing (OP6 copy) which meets up to rb25 dump and manifold. it is a 0.71 AR. i just dynoed it the other day with cams in it no and made 290 rwkw on 1.2 bar.
personally i think 0.63 is too small for a 25
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
