Nice work, I intend on making on of these, my question is ; What else from around the house can I use to heat the perspex
$15 heat gun from bunnings, otherwise blowtorch & wrap the perspex in tinfoil to stop it burning
toddlls idea isnt bad, but I found it was much easier seeing where the perspex was that I was melting.
BTW, I tried a normal hair drier and it didnt work :)
honestly, at bunnings I bought a cheapy heatgun for $12-15 bucks and it worked a charm. within 30 seconds it was almost like honey.
Gl with it.
Adam
  • 3 weeks later...
  • 7 months later...
your welcome guys,
also turael, i'll try to get some pics up over the next few days, cant believe its been in there for almost 2 years! But i can tell u now, run over it with a wet cloth and dry... still looks like the day i made it.... and I will prove very soon.... Not to mention i have taken it out to work on things and rested tools on it heaps of times!
Not a bad idea, the Perspex looks good. I made my own also, although I went a different way. Is yours actually fastened to the body? or just sort of slots into place?.
either way looks good, Top job.
I must say after 2 years it still looks great!
I was thinking of making a hole in the top and make a fibreglass tube from the snorkel into the top.
Will post pics when I'm done!
  • 4 weeks later...
OK first up i gotta say that the heatshield looks awesome.
BUT... I have to ask...
You used perspex to make it from (I guess it's good coz you can still see the pod somewhat), and you used a "heat gun" to shape the "heatshield"....in other words since perspex changes shape with heat, how hot does the engine bay have to get before it melts??
very hot dude, like yeh if u placed the pespex on the exhaust manifold it would melt... but if you look it up on wiki:
http://en.wikipedia.org/wiki/Poly(methyl_methacrylate) its melting point is 130-140 degs celcius
and the heat gun was direct heat, whereas you'll find the heatsheilds normally just suffer from indirect heat like heatsoak from a hot motor...
Adam >_<
Im keen on doing something like this for summer, oh and wicked job btw.
Does anyone know of a more heat resistant material to use? maybe some aluminium sheet metal with heat sinks around lol.. a little over the top?
Also have you had any problems with police? or is it perfectly legal?
thanks.
If anyone has some air temperature sensing equipment I could borrow to give some results, or if someone can point me in the direction of where to buy one within the $200ish mark i'll get some results.
I bought a fairly cheap 'automotive' multimeter from dick smith ot radio parts a while back which also came with a K type thermocouple or what ever they are called. You can plug it in and run the wire to the air box etc. Unfortunately you don't get two sensors two compare at one time but you do get a multimeter out of it too. Maybe one of your mates wants one too and then you'd have two readings?
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
