Hey man i sure its likely to change dependant on car and POD etc but what size acrylic did you start with, I called for a quote of 1mx1m just on the basis of "im positive I wont run out" and it was like $130. Having said that yet to try bunnings but thought id go for better measurements than my glorious guestimation
  • 1 month later...
Wow awesome shit ! i made a cai for my R32 gtr and been looking for a way to get a proper cover going to cover the heat and trap the nice cold air.
i will give this a shot :)
Good Tut man !!
My one on my r33, thats what happens when your bored.
Edit: By the way thats a piece of plexi glass where you see the hole so you dont think what a douche bag left a hole at the top.
Edited by MrRx7s3
I finally got around to doing my airbox on the weekend and am pretty happy with the result.... I thought i would cheat and buy a JJ box and modify it, turns out it would have been just as quick to start from scratch but for about $100 i am still happy as i was quoted $375 to have one made!! :thumbsup:
Good work on the tutorial though!!!
  • 9 months later...
Did mine a couple of days ago. I bolted my AFM and pod onto the perspex though so it was fixed. I don't know if it is placebo or reality but it feels like the turbo is spooling quicker.
Also a tip for others, when I made the template I used a metal coat hanger to form up the bottom edge and then traced it onto cardboard. Much faster than guessing.
that looks fantastic. did you just follow the OP's tutorial?
You can buy them pretty cheap for the R34 man, just dont buy the shitty plastic version, get the alloy one but run a rubber strip around it....
Basically, cost about $70 all up but I have enough perspex left to make a second one if I want.
Guys, good to see my tute is still going and people are producing some great results!
Just thought i'd post up my cover is still working great. It's been through 3 different pods - now onto a monstrous one for a bigger turbo and it still is doing it's job. Unfortunetly I have scratched it a bit using it to rest tools on but other then that it's still in good nick.
post-36975-0-95192500-1358473144_thumb.jpg post-36975-0-89434100-1358473145_thumb.jpg
  • 1 month later...
Thanks Adam, massive inspiration, i just made my first template tonight so hopefully on the weekend over to bunnings for some tools+ perspex and off we go! having said that, what else can i used to cut the perspex as I don't have a jigsaw =( old fashioned hand saw ??!?!? hahahhaa
  • 2 months later...
  • 3 weeks later...
Hey guys, popped down to my local bunnings yesterday and they had several sizes available.
Can anyone shed some light on which size sheet they bought as they only had clear,red or blue in stock and would need to order black. There was a $39 but it looked too small to bend into shape. (can see OP spent $40 but not sure if same size). The next size was $59 (iirc)..
  • 4 weeks later...
Hey guys
Great write up
I'm about to do this to my 34 did any one have to remove the coolant thing if so were did you move it to or replaces it with any help would helpfull
All ready have a CAI kinda just left one on the pipes from the old intercooler from when I got a GTR one put in
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
