Official Launch At Melbourne Motor Show
  • Replies 72
Please excuse my ignorance but what is an independant transaxle?
pretty sure the independent part refers to the suspension (aka independent suspension) and obviously transaxle describes the trans/diff/axle combo.
do some homework?? lol tell that to the whole world then. the gtr is the first to have independant rear transaxle.
Thats what they claim, and they wouldnt get it wrong :)
"The Nissan GT-R features a newly developed Premium Midship package, including the world's first independent transaxle 4WD developed independently by Nissan. "
i missed the 4wd part.. but its still the one and only going around
They might be the only company to make a AWD rear mounted independant transaxle. A big difference to what you said though. Like I said. Do your homework as there are a lot of rear mounted independant transaxles on many different cars.
Nissan marketing also told me at the Melbourne motor show that their R35 GT-R was the only one in the southern hemisphere... Marketing is like that... You're not paid to tell the truth all the time...
What is an independant transaxle?
edit: I have a horrible suspicion that either a) nobody knows or b) it is what nisskid said
Might as well stick an Radial Tuned Suspension badge on it while we are there.
Edited by Laurence
a transaxle is a rear mounted gearbox and diff in one unit driving the rear wheels. independent refers to the suspension arrangement at the rear as being an independent rear end. they have combined the two. also, we can all stop saying 'rear mounted transaxle' by it's very definition a transaxle is mounted in the rear. it's like saying atm machine.
as for it being the first independent transaxle i'm not sure. there have been a few road cars with transaxles over the years but I don't know many of them in depth. I have done a bit of work with alfa transaxles and they are a de-dion transaxle (ie not independent). It's still not clear to me whether or not they claim the first independent transaxle, or the first independent transaxle with AWD.
So an independant transaxle is a transaxle... :)
Sorry for doubting you Nisskid, I just expected a bit more from Nissan's jargon department.
To be honest I am not sure that it should be called a transaxle at all, looks to me like a normal gearbox slid back with the diff welded on the rear.
Edited by Laurence
lol I thought you were joking... I kinda thought it was obvious...
A transaxle is when you combine the transmission and the differential.
An independent transaxle is when you do not mount it directly to the engine.
A rear mounted independent transaxle is when the transaxle is mounted at the rear of the car.
A rear mounted AWD independent transaxle is when you combine all that and add a secondary drive shaft back to the front..
Nissan have the first REAR mounted AWD independent transaxle but not the first independant transaxle or even the first independent AWD transaxle as the Ford RS200 had a independent FRONT mounted transaxle with the engine in the middle of the car.
Does that help?
Does that help?
No, it doesn't at all, because now I have two different but perfectly cromulant answers to the same question.
Hehe, well I guess it isn't. :)
Richard's explanation is perfectly reasonable except that it wouldn't really be so great to mount a transaxle to a vehicle with non-independent suspension (live axle) as you're adding a huge lump of unsprung weight. So to add the term independent in describing a transaxle would be slightly redundant.
I look at it as jargon and marketing hyperbole so take from it what you will , both answers are right ! its the marketing guys who dish out the buzz words and leave the actual technical explanations to someone else.
*cough* :) and we look a few posts back and ummm... errr
Anyway, enough bickering. I got the answer I needed which is that it is essentially a meaningless bit of marketing jargon rather than some particularly useful technical distinction. I mean if I couldn't work out the R35 was IRS or the engine was not connected to the transmission I would have the answer to why my knuckles drag along the ground when I walk.
As always SAU provides a nice mix of infotainment. Thanks ;)
lol are we all ok now?
I can't think of any other front engine 4wd/awd that has a rear mounted gearbox/transfer case/transaxle. It means you need 2 long driveshafts - engine to gearbox and then gearbox right back to front axle. But it was kind of an obvious design step once they decided to go rear gearbox, might as well put the xfer case back there as well.
BTW love the pics Laurence I am keeping them for when the school holidays come around
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
