  • 2 months later...
  • Replies 70
I got the V.I.O POV.1 I love it it's rather expensive much more then the go pro, but I saw someone with it snowboarding on their helmet...Lets just Say I'm happy I stuck with my decision, I love it quality is awesome it's tiny and it's very versatile
I saw the Go Pro Hero in issue 72 of AutoSalon... ...Think this might be the one I get... ...It seems to also be the only unit in the market that is Mac compatible...
Just a few things keeping me back... ...It says it can only have 2Gb SD cards... ...I've got a few 8Gb SD cards lying around since I changed to a Sony "happy snapper" and had to invest in new cards... ...It seems to only run off batteries... ...I'd like to see a lighter plug power version... ...No "Shock Record" with leading buffer... ...If you're out in the street and happen to be in an accident it would be great if it could start recording with a few minutes pre-recorded before the accident...
There was a duel camera setup (outside and inside the car) a few issues ago in AutoSalon that had the features that I want... ...However it isn't Mac compatible... ...So no go for me...
If the little Hero could take bigger cards and record longer with bigger cards... ...then I would get it...
  • 1 month later...
I think they have a newer model which can read the larger SD cards now, something they didn't tell me when they sold me my Hero off the shelf... probably getting rid of old stock and it was more expensive than if I bought it from Lucas. Oh well.
Picture quality is 'okay' for the price, but I wasn't happy with the sound or the vibration (which I fixed by wrapping gaffa tape around it, I know this isn't hard to do, but another process all the same).
Look closely at the picture (when all is still) and you will see a heat like warp in the picture, sometimes its much worse and I think its electrical interference
  • 1 month later...
Still haven't bought a mount yet... I really want to get one for PI. The clamp style is my preference to clamp onto my half cage. It's a pity there is no one locally who makes one..
http://www.racerecall.com/mounts__cases.html
  • 1 month later...
Instead of making a new thread... ...I'm going to Bump this one...
I got me a Go Pro Hero Wide MotorSport kit... ...I ordered it from the U.S. and it arrived yesterday... ...It will be coming out on the next cruise for sure...
  • 1 year later...
I use a VIO POV helmet camera which came with a mount which holds the tiny camera on with really strong magnets. Quality is ok. Here is a pic of it on my roof.
Edited by phoenix88
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
