Which of these pistons should I buy for my RB26DETT build?
CP Pistons, Wiseco or JE?
They are all relatively the same price (under $1,000)
In terms of the build I've just gone with ARP rod bolts, ARP main bolts, ARP head bolts, ACL main and rod bearings, etc. etc.
Nothing too too fancy.
Greg
  • Replies 41
The CP pistons are around $900 or so with rings + freight ($50 or so)
All up with ARP rod bolts, ARP head studs, ARP main bolts, ACL main and rod bearings I'm hoping to come in under $1,700 or so *fingers crossed*
Greg
Advice in terms of what rings to use??
I know a couple of big workshops source their own custom rings and pins to suit the CP's, but I couldn't confirm the specifics as I gave my CP's the flick and went to Tomei instead.
You have the option of using different pins and piston rings when you buy CP Pistons. They have about 5 different pin and a premium CPN ring set...
Do you have any more info on this?
I did a google search but couldn't come up with any info.
I have used CP in all my motors, no problem at all. You can get them from the US on ebay for under $700 a set delivered.
Ditto,
Ive got 8 Silvia SR20s running in the 11's on regular CP's, quite a few RB's as well.
Funny that i ditched the Tomei items for the CPs.Call me crazy.
JE are the better piston out of the lot, but why pay the price for a JE when you can buy 1000hp CP's off the shelf cheaply that'll do job just as well, they're going in my next build! I wouldn't worry to much about the rings on the CP's, more so the workshop you use to put your motor together, a motor is only as good as it's builder..
This is what I've been quoted so far:
> CP Pistons, 86mm, $879.80
> ARP Head Studs $360
> Cometic Head Gasket $168.69
> ARP main studs $165
> ARP rod bolts $84.93
> ACL rod and main bearings $270
All the above prices are in USD and are excluding freight.
Freight all up is around $110USD.
> ARP Head Studs $360
> ARP main studs $165
For *$110* USD that sounds like the best deal i've ever heard! :laugh::down:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
