Hope you guys can help me out here, has searched the forum without finding an answer!
Its said that the Rb25det pistons on the R33 gtst fails at about 450hp, and my question is if they cant stand the heat they're exposed to at that output, or if they fail mechanicly/cracks and go to pieces?
Cheers!
-David
https://www.sau.com.au/forums/topic/209149-how-does-the-stock-pistons-fail/
Fatigue, mechanical loads, elevated piston speed, and in most cases I would say knock due to poor tuning. Broken ring lands is normally the evidence to look for.
I have heard of some picking up in the bores from heat, but that was of the out of coolant / engine overheating variety.
+2 - det induced
Setups that aren't over revved, and aren't subjected to high temps, take a lot more 450.
I don't think its the heat that would kill a piston (hurt its metallurgical strength) Rather, I think the heat would cause det and that would kill it.
The piston can fail in the ring-land region because it cannot stand the amount of explosive energy its being subjected to... Tuning can help tempretures and detonation, but the more boost you run, the more explosive force being generated, the higher the stress on the piston.
Oh dear.
A few fundamentals:
The compressed fuel/air mixture in your cylinders does not explode. It burns, quickly. There is an important difference. An "explosion" is referred to as detonation.
Detonation will, as has been pointed out, rapidly destroy your pistons (and bearings to boot).
A properly tuned motor will not detonate, hence it can be ruled out as a cause of failure AS FAR AS THIS QUESTION IS CONCERNED.
Which leaves up with what as a cause of failure? Well, amongst other things:
Too many rpm.
Too much combustion pressure for the rings either because of insufficient tension or simply old age.
Too much combustion pressure helping accelerate bearing failure.
Insufficient cylinder cooling. Note that the strength of metals (particularly aluminium) falls away markedly as temperature increases.
But don't forget that pistons etc wear/distort and generally suffer from mileage and hard work. So whilst your 450hp RB25 may last for a time it wont be forever and probably not for very long.
Really helpful answers i've got!
Since i live here in Sweden and at extremly hot summers we've reached just about 30 degrees Celsius, or 85 degrees Fahrenheit i guess its about the same temps as in Japan? Anyways, right now its 0 degrees C or 32 degrees F outside. I f i consider outside temps a big part of wareage :thumbsup:
What i was thinking of when posting this thread was if it was worth spending good time mapping it as good as possible, and through that push the rebuild of the bottom a while, atleast about 6-7 months. I was heading for the tracks this summer, but now i'm probably best of with rebuilding it before i push it to hard. Probably ill start with keeping the boost at about 1.2 BAR as a maximum and after the rebuild head for higher boost if needed.
Since i'm going TT (twin 2530's) with my RB25 i was wundering if you've can help me decide whether to go with twin Z32 AFM's or just a single Q45, joining the air-intakes on the turbos?
Cheers and thanks for your help!
-David
Wow considering most people in this thread are from Australia and extremely hot summers are low to mid 40's Celsius external temp is probably not a major consideration.
30 degrees Celsius
Lol'chops, yah we get many a low 40's in eastern Oz.
Its not so much the external air temp, its the combustion temperatures (500-1000C) Those last few 100 degrees are more about AFR ratios, boost pressure and advanced ignition IMO.
I'm in Okinawa, Japan, so it's pretty warm here. It's a sub-tropical island. It gets into the 50's (sometimes the occasional 40 something) in the winter and will tickle 100F in the summer, but it's humid as a mutha.
Can be really annoying if its too humid, had one of those big thunderstorms a while ago, could cut watercubes out of the air for days!
Just started to polish the 2530's yesterday, spent 2 hours on one of the compressors and it came up better then i thought, but im not done for days yet, its still very grainy so ill hit it with a wet&dry P150 and start over again :/ But practice makes perfect! Then its off to TIG-weld a new manifold and new downpipes and fit em!
Heres a quickie :D
Good work dood, polishing is a farking khunt by hand... did a RB26 plenum.. never again.
PS: Humidity is g o o d for petro chemical combustion motors. Water vapor aids chamber mixture outer shell shedding. (burning)
Embrace the shirt sticking your back rofl.
Im running 500hp flat out on the track with a stock 25. So far so good. It all comes down to supporting mods. Ie good tune, good cooling, good turbo, cooler and exhaust.
They are renound to be fragile. They crack eaisly from knock from what i have been told.
I 100% agree. Seems some on here think they will magicaly explode after 400hp, but i've been will above that figure for almost two years now, and have several friends that are the same, but beat there cars WAY more than me.
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
