  • Replies 161
Should be a enough time to recover from the night before so put me down.
...anyone else want to see weak'soz take the Schnitzel challenge. There's $25 on the table if ya can finish it off in 25mins mate.
I think i could bring someone you know who could do that challenge!
Shame you dont actually get the free beer if you do it!
yep put me down too - tentatively with the +1.5 but not positive if they will come or not.
Sweet, yes some more Buck Hunter action would be fun Luke - even better if there was a South Park pinball machine too for me to rack up a heap of free credits on :D
Hopefully get a good turn out for this :D Should be fun!
Will try not to get too drunk this time :D
sure sure
pete, better bring the SLED again, sounds like photos mite be in order hehehehe
ill probly make the booking a week before to be safe so lets say by Monday 24th i will make the booking, whatever number have said yes by then is the numbers i will book for.
mawson lakes is normally always bookings only on friday and saturday nights, so unsure if they will be able to accomodate more, what ill do is take the number we have and just add a couple extra so there is still time for last minute, unorganised people :thumbsup:
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
