watched a performance dvd the other week and there was a performance/race car on it that had a large intercooler in the back with twin thermo/cooling fans pulling air through intercooler.
i was thinking it is a good idea because it will always have cool air flowing through it.
when using fmic setup air gets forced into fmic while in motion, but if front mount has cooling fan pulling air through it would make intercooler more effective and efficiant...
saying all this if this is right, would putting a fan behind my fmic (pulling) create more of a gain? especially at standstill when intercooler is not getting air forced into it.
any info will be great or if anyone else has any other ideas will be a bonus.
4drftn
yeah sh@un is right, no gains to be had
it was probably a radiator/cooler combo at the rear because they'd run out of room at the front, the fans were probably just to push air through because it'd be lacking the wind you get from the front of the car
spend a little time making some foam air guides (or a nice metal guide if you have the skills with the material) for between the intercooler and radiator so the air doesn't 'spill' making the standard fan setup work more efficiently.
sorry i may have not explained myself well, but i am already running viscous fan+12inch cooling fan infont of my radiator pushing air into it...
now... what im actually trying to find out is benifits from having a pulling fan on the back of an intercooler or fmic, in other words trying to get more air and cooler air into intercooler to maybe produce more power etc.
sorry for the confusion
4drftn
i have seen this done, it was set up to come on when the intake temps go up to a certain temp, only really usefull and low speeds or stopped when there is not enough air flow over the fmic.
Id start with measuring your actual intake temps, take a common, do some plots over time, otherwise your just faping into a carrot cake.
Water spray while standstill i find isn't soo effective (well not as much as Id want it to be) The water itself isn't cooling the IC, its the latent heat thats absorbed in the state change from liquid to gas (evaporation) Hence, without the air moving over it, kinda hindered.
Thermos and a water setup could work well me thinks, if you really need to prevent heat soak while standstill.
If state change heat absorption is your game, iv always been interested in those C02 IC sprayers. C02 is dirt cheap, and in 30s can have a ice covered IC when dead still. I had almost ordered one, but a change meant it wouldn't work with my setup.
Thinking aloud :/
EDIT: After getting some base figures, first try air guides first as mentioned - a must.
Edited by GeeTR
When the intercooler is working hardest is when you're in motion- meaning there's plenty of airflow already over the cooler.
water-->air intercooler would be the best upgrade, esp. for heatsoak issues, but it's not exactly a simple bolt-on upgrade like a regular fmic.
Airguides ftw, maximise airflow to the cooler. In the meantime you might want to put a fan behind the fmic and do some tests with a thermometer-type tool and see if the fan makes a difference to charge temps and cooler heatsoak temps.
Air -> Water IC's (what i think you meant) still needs a heat exchanger (rad like)
People use thermos on those heat exchangers... thermos on a Air -> Air should work just well maybe?
Try it, let us know :/
Edited by GeeTR
i think i most definatly will give it a go... aswell as air guides for maximum gain. does anyone have any pictures of an airguide they have customly made for there setup?
also how would i go about measuring the air intake temp/amount? will it be in ECU data?, i have a microtech LT-8 ECU, should i be able to access that sort of info?
cheers
Always wondered if 12 volt peltiers would be the go. Peltier runs on electricity gets hot one side and very cold other side smaller ones can cool cpu in computer so i imagine larger ones could be utilised in aiding to cool an fmic? just a thought
The short answer to this is : don't waste your time.
A properly ducted intercooler will take advantage of the high pressure built up at the front of the car when travelling at any reasonable speed.
This pressure build up will be more than any fan is capable of providing.
Hence installing such a fan is a waste of time.
But:
If your car is a GT-R it already has a fan installed to push air through the radiator. You can hear it click on when the car is sat idling on a hot day.
It is far, far easier to plumb in some water misting to spray the intercooler when the inlet temps go above a certain threshold. Why don't you look into that?
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
