Hey guys,
For those members around Chatswood/Artarmon area - do you guys reccomend anyone for a wheel alignment and settings changed forcamber/caster etc for track days/sprints etc?
Been a while since last adjustments made and done a few days on them, just need to check if everythings good and make adjustments if need be.
I know theres a pedders...but does anyone else know of other shops?
Cheers,
Chris
Chris, I think Pedders are your best bet - They did some work on my GTR that I was quite impressed with.
TCCA ie H & R are a Euro focused workshop, the guys at pedders have done a lot of Skylines and should be able to set your car up to your specs without a problem
Thanks subie, Nick and Nick! :action-smiley-069:
Blitz - I met the area rep for pedders @ summernats, he no longer works there though and I actually would trust him, but yeah, if they have done work to your GTR, I'll give em a bizz again
thanks guys :)
thanks guys :)
I forget the guys name that did the work, but it was a young guy and I think he and his old man owned the place, Scott maybe?
yeah father and son own it. they were pretty good, but I don't like anywhere with a laser alingment machine. very hard to get repeatable results imo. now adays I either do it myself with string or take it to heasmans. bit of a mission, but worth it. :whistling:
Go and see scott at pedders artarmon... i had problems with my old pulsar the day i was trading it in for the skyline and he fixed me up no probs... After getting work done there i nearly didnt want to get rid of the car.. one of the best wheel alignments ive had.
TCCA is also a good workshop.. located just down the street.. Bumped into a old mate on thursday night and found out he was a head mechanic there!
Peter at Road and Pace Performance at Rydal mere (Couple of k's out of Parramatta).
Experienced racer, builds great cars. He installed my Whiteline group buy kit and made my GTR feel the best it has ever been.
Someone from this forum with a 33 gtr recommended him to me.
Shop No: 02 9684 2826
Rydalmere isn't really near Artarmon mate :teehee:
U'll be able to rest easy with the car there
Yeah so far so good!!
Will give the car a good work out at OP saturday, but so far feels more stable!
Chris gave me a few pointers also so lets hope its all good!
cheers!
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
