Hey guys just interested in other peoples opinion on my situation. I was ready to sell my car but a month or so ago my r33 ser 1 caught fire as the rocker cover was leaking on the exhaust and it was heatwrapped so it just got soaked with oil heated up and sorta combusted. Now all thats been damaged is the coilpacks/power steering resovoir/ tiny bit of wiring and just general breathers and vaccum lines on the right side of the engine where the exh manifold is. The car has been listed as a repairable write off (dont ask me why) and have been payed out on my insurance claim and they have GIVEN me the car back! The way I see it, its gonna cost me under 1k to fix and have back on the road ready to sell anyway.
Is it worth fixing up and selling? If so How much are they worth nowdays with the following mods?
Or what do you think its worth in current state from what ive described?
Modifications
Full exhaust with Nismo Tip and Screamer Pipe
Hi flowed Turbo by sliding performance
2 Way locked diff
Front mount
Bored throttle body
Apexi Pod (Brand new)
New 1.2mm Cometic head gasket and machined/tested head
16inch Advan racing 3 spoke rims
Drift steering wheel
Sunroof
Type M/Mspec whatever it is standard bodykit
An over all tidy car, black in colour
Thanks guys will be good to hear back from you.
Edited by Jamie88
https://www.sau.com.au/forums/topic/209991-r33-caught-fire/
geez you came out of that alright! just fix it up and sell it cheap and with your insurance money as well you'll be set.
What does everyone think is a fair price nowdays. 13k? I know a year or so ago they were selling for 15+ with similar mods.
https://www.sau.com.au/forums/topic/209991-r33-caught-fire/#findComment-3716853
If its a statutory write off and you got paid out wouldn't that mean that its not registrable anymore?
Its a "repairable write off" so once its fixed and passes the inspection its fine to be registered again. And it was insured fire and theft for $10k I payed more when I bought it but thats all thrid party would insure for.
https://www.sau.com.au/forums/topic/209991-r33-caught-fire/#findComment-3723054
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
    • Well, yeah. But I just expect everything other than my car to feel like a bucket of shit anyway. I still miss my Alfa 116 so much though. You could run over a 20c piece and tell whether it was heads or tails.
