Spotted a silver V35 on last Friday, drove very fast :D (90-100km)from Pyrmont up to Anzac bridge and turn right to Victoria rd.
What a lucky night.
Spotted 5 V35 coupe in one single car park ( Include myself) together at Eastwood NSW last night. 11/08.
One light blue (Factory color) with stand 18' wheel.
One silver with 18' wheel and reverse camera
One silver with plate "CPV350"
One silver with big Trust style front bumper ( Not 100% Sure whether it is trust or top secret )
I was the silver one with NISMO wheel and 06 projector light.
WOH>>>>>>>>>....................
What a night.
Frank
that's me~its my daily route after work (graveyard shift)
as I spotted so many Vs on weekend trip in Sydney:
sunday - silver coupe in Syd CBD with black euro plate ends "777"
Monday - white/silver coupe in Syd Chinatown, on Hay St or Sussex st cant remember~
Tuesday- silver coupe near DFO Homebush with exhuast mods
- not sure if the same as the one above but coupe parked on the side of road near Strathfield station
I spotted you again this morning... didn't catch the badge on your boot, is it 250GT/300GT/350GT?
What a lucky night.
What a night.
Frank
LOL - you gotta really be an innocent/uninvolved bystander to be an eligible spotting... but for the fun of it, why not... and looks like u had fun
Yep.
Most of them are standard. No too much to say.
I am really exciting about 5 of them in same carpark same time but NO A MEETING. LOL.
Edited by Frank350GT
Spotted xcape237 in pieces this morning, getting the treatment from Chris in Boronia, hahahaha. I had a look at your car mate, very nice, love the wheels as you know, nice to see them in person!!!
Rianto....I don't know mate, Chris is running a little late and my car wasn't ready last night, pick it up tomorrow...sometime. When are you due in???
But it should be right, Chris is here until Saturday, and I'm sure he won't leave until you are done this time!!! :D
I'm due in tomorrow... but mine hopefully won't take too long...
maybe you did, what time do you remember ogz?
I had a pretty hectik saturday last week running around looking for my first home/unit. looked all around rooty hill, blacktown and parra region, I'm over it already >_<
hahaha yeh, you looked pretty busy that time i saw ya, around 1:00 - 1:30ish arvo. i was ready to wave hello to you but you didnt look lol. i was with a black 350z heading to big chief. Man goodluck house hunting bro kinda tough around those area.
Have you looked around the new area in woodcroft? Or Bella vista waters area? I think theres a project there for new apartments.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
