Might be mine, around what time and where abouts at Hume hwy?
About 7.10 ish Not sure if it was silver or grey. I think it looked grey. All I was thinking was what a nice colour and sheen under the street lights. you were in the middle lane. I was trying to speed up and check it out but unfortunately got stuck behind cars that wouldnt go 70!
Ah haha ;) well if it has an after market exhaust and white license plate light then that would be me
Well I wasnt paying that much attention to ur lic plate or exhaust - mainly because I need to get my eyes retested. i was looking at the colour trying to figure out if it was grey or silver and trying to drive at the same time :geek: . it had to have been you because i didnt see any others that night. I should have tooted.
Seen two silver coupes today, charlestown square. one bog standard premium and another premium with big wheels bought from like bob jane because everyone has them on commies in newcastle, with tail light tint. exchanged looks and thumbs up
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
