In WA
seen one silver orrong road this morning peak hour.
another silver on Friday, intersection of Albany and Kenwick Link.
That was probally me on orrong road, I drive down
That street ever morning in welshpool.
White V35 on Saturday morning. Down the street from my house.
Missed the license plate though..
in sandhurst.. anyone here? I was going to leave a note, but was in a rush to get new tyres and had to make sure i missed the rain
Silver V35 Coupe on FTG Road Scoresby twice yesterday then Silver V35 Coupe on Eastlink last night.
Blue V35 Coupe Glen Waverley pulling out near the Ibis about 5:45 this evening.
May have been me depends on how far out on the eastlink.
I did have a clean and badged Stagea next to me from about dandy to Thompsons road...
Just remembered a Sliver V35 in Geraldton pullin out of WestSide Detailing/Geraldton Property Team at the start of the month. Haven't seen since. They might have been driving though town. (All Stock)
Yeah that was you then.
Was along side in the Stagea for a while. No badges.
Spotted a white V35 Coupe going through the Brisbane CBD, passing Gotham Tower (That's what the locals call it. Think it's JAG). Looked stock but very clean. I think it had the cream interior.
Spotted today: West Australia
About 1pm in Midland
Underground carpark
Carbon fibre bonnet, full kit w/after market spoiler,
anyone here?
I spotted this same car today on Marshal road in Beechboro. Also spotted a silver sedan, lowered on reed hwy in west swan.
Alright own up there was one other V35 with full black rims on show inside aswell as me outside, annnd 3 other V35s showed up for a look, one was GED, 1 had black rims with 255s on the front an 285s on the rears tyre wise and 1 more I didnt get a chance to look at becoz u hid it somewhere, who was there today?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
