I've got an auto R33 gtst-series 1 that I got recently, and my fuel consumption is about 280-300 kms per full tank.
So from what I've read so far, changing the O2 sensor, plugs, might help. Also I didnt get what the ecu + remap + piggy back does and would it cost too much?
thanks
  • Replies 74
Posted Images
off the bat, just replace the O2 sensor (they're liek $80.00 new delivered from KUDOS), and give the AFM a clean with carby cleaner.. stock air box helps as well, and check for leaks.
nothing wrong with stock ecu if you don't plan to run many mods
If you have a PFC make sure the O2 sensor is turned on.
my tuner left mine off and was wondering why i would get 17-18L per 100km just cruising around.
It dropped down to 13L per 100 once on. hopefully get it a little lower once my tune is touched up today by a different tuner :cool:
If you have a number of mods it can cause the stock ecu to not be ideal for the modified setup. One thing is the ecu can go into rich and retard mode which means it adds extra fuel and takes out timing. This is more under power though but as you can see will worsen your fuel economy.
Custom tuning can also further optimise your afrs for better fuel consumption.
provided it works!
mines permantly disabled and I cruise at 14.7 a/f usually get up to 400km city per tank of enthusiastic driving at 1.3bar
but saying that, he runs a stock ECU
  • 2 months later...
  • 1 year later...
ah you want to know the secret to getting more Ks from a tank eh?.... I dunno guys should we tell him...
I know it an old thead but I have the secret
How do you all drive your car? It must be Full no, off, Full on, off
LOL funny
I must have the secret, here it is
Buy a hr31 two 2 door skyline. Put in it a RB25det neo in it then a rb26 gearbox and a chrome-moly flywheel, brass button clutch, bosch 040 fuel pump , adjustable fuel regulator , Apex bov, Turbosmart boost controller, Big front mount intercooler, plenum and 68mm XF body, hks cams,Oil cooler and oil filter relocation, micro tech LT-12, TO4 Turbo 69hks inlet wheel and 0.7 housing exhaust , Tial wast gate, 10l sump (for Oil), head std kit (ARP), mean std kit(ARP), commadik head gasket, gates timing balt, N1 oil pump.
and made 350rhp ish on 12psi on pits dyno and If you drive it like a normal person and you get 550ish + out of a tank. Drive like a wanker and you get about 300ish.
WIN WIN WIN ON FUEL
Just switched back to 98 after 18 months or so on E85. (Around 240rwkw)
So far on the first tank i'm up to 320km and about 1/8 of a tank left. There has been very little cruise going on. I would say 80% of the driving has been foot to the floor (very little O2 use).
Very surprised at the economy. I would love to take it for a long country drive to see what is possible but it's too much fun on boost :)
Jimmy
Hey, that's funny. I was just about to head out and buy hr31 two 2 door skyline. Put in it a RB25det neo in it then a rb26 gearbox and a chrome-moly flywheel, brass button clutch, bosch 040 fuel pump , adjustable fuel regulator , Apex bov, Turbosmart boost controller, Big front mount intercooler, plenum and 68mm XF body, hks cams,Oil cooler and oil filter relocation, micro tech LT-12, TO4 Turbo 69hks inlet wheel and 0.7 housing exhaust , Tial wast gate, 10l sump (for Oil), head std kit (ARP), mean std kit(ARP), commadik head gasket, gates timing balt, N1 oil pump.
Hoping to make 350rhp ish on 12psi on pits dyno and If you drive it like a normal person and you get 550ish + out of a tank. Drive like a wanker and you get about 300ish.
i'm a bit out of my legue here but i own a 98 nissan s2 stagea rs4
many problems with fuel economy
albeit many people here have big problems with their setups but i found the best fuel saving device was a boost guage
under vaccume the map uses the o2 sensor and leans out the engine, boost means the ecu runs a default map which is typically rich
in summary when you hear that boost whistle it sounds like this $$$$HHH
keep of boost and you are saving a bundle
Lowest i've seen out of the DE+T is 9.1L/100km. Easy highway driving, with the occasional WOT 3rd/4rd/5th coming into a 100 zone. Fresh plugs, coils, fuel filter, pump, 02 sensor, clean AFM, good oil and good maintenance helps the figure.
State of tune helps also. Plugs, coils, ECU and it's relevant sensors (o2, MAF), low fuel pressure, big tyres, poor alignment, carrying excess weight etc. etc. will all affect economy. Driving style will be a MAJOR factor over all others though...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
