was following a white R34 on narre warren north rd down onto narre warren - cranbourne rd with green p plate on rear bar and a very nice R33 comming out out laurdadale rd ( i think its it) with DAYMOE plates
Spotted a number of 33s around Dandy today... ...nothing too stand out really...
Saw a red 33 as I was pulling into my GFs place this afternoon... ...He flashed his lights at me and gave a wave... ...I returned the wave...
I think he flashed because I had my lights on... ...I tend to drive with them on most of the time...
also spotted a few r33 around dandy yesterday... a stock looking white one, a grey one and a nice burgundy one with personalised plates but for the life of me I can't rember what they were...we were sitting opposite you at some intersection.. I was in my mates r33 white one with r34 rims...
Silver S2 GTST on Riversdale Rd, near Camberwell Junction at about 1pm today. Think the plate started with TSN. Had SAU stickers on the quarters. :thumbsup:
I'm pretty sure that would have been me. I was just getting some lunch with the gf on our day off
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
