the other day on princess hwy, black r33 gtst s1 with ferrari emblem on front quarter and gtr badge on the back......seriously mate what the f*ck is goin on there?
LMAO people like that make me laugh
I once saw a gts-t V-Spec must be worth a fortune seeing as its the only one i have ever seen ahhahah
love how every monaro pulls up next to me wanting a go then backs off as soon as they hear the turbo spooling.... ahh the only advantage of having no air filtration at all :thumbsup: zzzzzzSSSSSSSSSSSSSSSSS
nice red r34 on sydney rd, nismo kit/gold rims
Edited by R-SPEC
Spotted a silver r32 on highstreet in melton
black r33 on highstreet in melton, down the westlake end, he gave me a stare then fluttered his blow off valve as he took off from the lights
spotted him again i think, about 20 mins later at the east maccas in melton
black 34 going down james cook drive in melton
May have been me, but i didnt go to maccas, itr wouldve been me if it had the big wing on the back. Could this be the first spotted for me??? hahaha. Dint mean to stare if i did, didnt see what you were driving, my platyes are 'siklin'
Edited by Damo_c
i've seen siklin in the past couple of days but i cant remember where. so yeah thats two spots for ya
didnt see the plates lol
i was in a white r34... it was at the lights near james cook drive on highstreet
I saw this r34 gtt last night completely covered with 'BURSONS' advertising!!
Does anyone know the car n wats up with it; the dude must own a shop franchise.
Im going for a drive now; they see me rollin' they hatin' ridin dirty'
AWD DRIFTING ?? hahah
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
