yea i always see DRFTN 6 in west suburbs drove along side u a few times on kingsroad n stuff...
Really what are you in? say hi next time :P
Spotted rbpowa tonight on pound rd
Just droped my boss off in dandy to pick up his new evo - 10 and was driving his evo 9 back to work and saw a GT-R R35 silver pulling out onto hamond Rd i gave him the thumbs up i think he thought i knew him lol i was creaming harddddddddd
was it pound road ? or sth gippy just before the round about ? cause i remeber a white 33 come up next to me, i looked but they didnt seem to interested so i assumed just another skyline driver.
spotted AP .. LEANBAC... in noble park parked outside the tafe thingy ... was gonna put a card just to make you look over your shoulder but had none on me!
white r34 at re customs before while i was there, gold piping.
and an r33 with on big thick blue line down the middle of the car on chandler road 7.30pm thats all for today :D
RBPOWA: are RE customs busy? i heard theres like a 1 month wait to get shit done.. i need to get a few things done but i cbf going if theres gonna be a long ass wait
right now ... no good, they have kinda stopped taking cars in, trying to get out as much as possiable before they close for holiday.
depending on what you want done, its sort of like just get in line, at any giving time there is 10cars in the workshop with bonnets up or up on hoists (only 3 hoists)
or there is dyno tuning getting done, means there is 1-2 guys down while that is happening. and carpark is always full out the front.
but the quality of work and the professionalism done to your car, its worth the wait rather then an overnight stay and a shonky garrage that in the end you have to go back 3-4 times to get it done right.
take all that into account, its really not that bad, wouldnt take my car anywere else, plus i have a spare car for daily duties :D
lol ye i dropped my car off tonight for fuel pump install and a tune which ibooked for last week. asked them if they can do a oil change for my diff and gear box and all i got was a errrrrrrr if we have time then yes lol. they are busy as shit. working till late. ray was working on mine till 11:30pm last week.
RBPOWA is you car back there again? think i aw a stagea on the hoist
spoted CAJFLY on springvale road around 2.30 and later on saw Adam in his rolla on springvale rd aswell.
+ few other r32/33s on princess :)
where bouts on srpingvale rd??where the hell were u im amazed i didnt ntice ya.
where bouts on srpingvale rd??where the hell were u im amazed i didnt notice ya.
umm at the high street lights on other side of maccas. i was like at the front of the lights lol. but doubt you would of seen me with those dark sunglasses on :)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
