Was that you in the skyline shirt on the phone as i was leaving the Shell??
If so hi dude.
That was me :laugh:
Nice car dude....
hope the fuel there is good... i will be filling up there as its just around the cnr from our new place :down:
dont know if AP is still in the country, but i seen his car down douglas street this morning around 930am
was behind a drunk guy in a ute doing about 30 k's all over the road, nearly had a head on and ran up the ass of a parked car. damn fool
i crossed cheltenham road that was about it Niroj
White R34 with Windshield sticker "nismo' starring at me down south gippy.
sorry may i dont wave to skylines, most of them are just boy racers, and not apart of SAU, so they might think WTF ? ...
but now a stagea man, you dont just buy it cause its a wagon right, its cause you know what it is, so wave :santa:
if ya's know what i mean
That was me :santa:
Nice car dude....
hope the fuel there is good... i will be filling up there as its just around the cnr from our new place :santa:
I didn't fill up there. Just got energy drinks. was a bit tired after some last minute x mas shopping. I only fill up at mobil.
if it was you that flashed me as you turned off and saw me stick my arm up out of the window then its was me. its RB26T....no D
unless theres another one around with RB26DT cause RBPOWA says he sees it all the time????
im glad you didnt decide to get beside me cause i had my mum in the car...how embarressment!!!
she wants to learn how to drive a manual so you might see an old asian lady on the streets in a black32 soon!!!
lol, yep that was me, you've got an incredible car man, can't wait to own a GTR (around 4 months away when I start my grad job :santa: )
Woahh awesome!!, coolest....mum.....EVER :santa:
Merry Christmas to everyone btw!
Cheers,
Sean
Spotted a nice white R33 GTR pulling out of BP on the corner of stud & highstreet roads yesterday at around 4.
Also spotted a silver 34 GT-T stopped on burwood highway (Roughly 12PM) buying flowers from a van which i just did in my GT-T. All these skyline owners looking after their girlfriends, geez we're a good bunch lol
spotted white or silver 33 gtst at chapel street back carpark, saw some mint s14's full showcar stats, one plate was [nocash].
then spotted series 1 r33 gtst around st kilda area around 1:30-2:00am
spotted r33 at st kilda beach.
also spotted v35 with sau sticker at autobarne dandy
& ealier on around 9pm or so r33 at eastburwood carwash
spotted a White r33 GTS-T with rims at the front and stock rims at the back on princess hwy just past the shell next to chap st at about 940 on the back of a tow truck........no more burn outs for u....
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
