:( wo hoo spotted ......... although it is an M-Spec
M-spec NUR....droooooool. Pics STAT!!
White 33 on the news (with sau sticker) - story about illegal street racing in the northern suburbs
:banana:
white or silver? i heard silver. didnt catch the program tho
spotted a blue R33 with SAU stickers on springvale road today, you beeped at me while i was stuck in my car and couldn't start it because my immobiliser remote was stuffed lol
just seen you out of the corner of my eye :huh:
Spotted a blue r34 gtr on the side of ferntree gully road with no rego plates on it.
Was on Saturday morning :rolleyes:
My friend saw that too on her way to getting tyres fitted.
She was worried it was my car!
Then on her way back she saw it being loaded on to a trailer with "a guy standing beside it looking distressed".
Hope all is okay for that car and owner!
Spotted a white R34 P-plater yesterday morning around 8:30am intersection of Darebin Rd and Station St in Thornbury.
By the time I saw you I didn't have enough time to react and wave back sorry!
Yayy! 1st ever spot in the GTR!! I seen you too Jake, i just didnt know it was you. Im still thinking you have an r32..
i actually seen it out about a week ago, forgot to post. out the front of a house in bellevue hills with another 33 i believe and the burgandy 32. i was in my 33
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
