Very interested in this, should be a great success..
Filling out form now but undecided in which class to enter...
I totally agree with djr81, street cars with Rcomp tyres would've been ideal, but I guess the rules are the rules!!!!
Now who will come second in open class????
  • Replies 1.9k
haha, join open class you pu55y jack! we both know you are fast enough to mix it with those guys. :P
and dave, if you are not driving the starlet let me have a crack in it! I am a terrible driver but an excellent talker. Tell us what times do you do in the starlet around OP GP? put some fear into these GTR drivers.
Why don't you make it a bit clearer: 'No Porsche car'
I can't think of any Major Car Manufacture that make rear engine 6 cyliner :/
yeah thats an strange one.
that part is actually open to interpretation, if its just no rear engine 6 cyclinder, what about the old Bettles they are rear engine flat 4. Ferrari F430, thats still pretty much rear engine, but its a v8 or the lambos, v10, v12 all rear engine but not 6 cyclinders.
Wrong, Ferrari's and Lambo's have mid-mounted engines..:)
BB - My car fits all the requirements of the Clubman class, except the tyres, hence why I'd get you to source some RE01R's for me and actually have a chance at the pointy end....
But after some thinking I've decided to go open, never been on the track in my car with street tyres...
However it will be interesting since I probably won't have any time to do a practice day to get familiar with the track... :D
I think I've changed my mind again... :ermm::/
if you want to try and do a practice day before hand you can share my loaner mate. :/
for sure on some good street rubber like maybe AD07s or the RE01Rs you would be up the pointy end of street class, but you may find on the semis you are still up the pointy end in open class too.
I also wouldn't mind seeing this evolve into proper grid start racing.
can't say I agree with that. if you want to go from this time attack style formula to door handle to door handle then you need to realise the changes.
cars would need to be log booked and have approved, welded in cages
drivers would need NC licences instead of L2S (cost goes from $100 a year to hundreds, and many more onerous requirements)
you would need proper nomex suits (min $600 worth of safety gear)
that is just the tip of it.
there are plenty of classes available if you want to do 'proper' circuit racing. this is a fun, cheap alternative. door handle to door handle means you need a budget of a least a few thousand per meet and a dedicated circuit car.
oh i know, but lets not argue about that, it at the back of the car no matter how you look at it. I'm just saying as an exmaple. It seems porche is singled out, dunno why though.
haha yeah i know it's expensive, I'm only dreaming.
Hey Guys,
Sorry but my computer is kinda stuffing up abit!
Can someone plz let me exactly whats going on with this?
Whats the actually date of this event?
And can anyone enter a street car??
If so how much is it and so forth
Once again sorry and any help will be appreciated
Help me!!! is there a class that my car will qualify for?
Its from a major manufacturer (its a March), its mid mount, engine is stock.
Can I come? purty please? Oh bugger! I'm pretty sure my tyres are R compound :down:
lol don't think there is much "semi" in those semi slicks.
Does that mean I have to get the pocket knife out and draw pretty patterns on the tyres?
Edit: I was being blind, I thought it said R's or Semi's - when its R Semi's.
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
