  • Replies 1.9k
Hi all,
I am currently trying to organise a trip for our NZ superlap winning car over to your inaugural Superlap competition.
In short , i am very interested to know how close the top imports are to the V8 Supercars on the same track or are they actually faster? (if they are , i'll save myself the heartache now and just quit :wub: )
Any info would be greatly appreciated.
Scott
As it stands for the moment Scott the imports are slower. However I dont think we really have proper times for most of the imports on the GP Circuit at Oran Park. You also have to remember that V8 Supercars run on full slicks. I am sure if you put some o our fastest cars on full slicks they would be very close to V8 Supercar times.
I hope you can organise some sponsors to get over here it would be good to have some friendly overseas rivalry. :wub:
-Nathan
Hi evil weevile i did not see your car there today so i did not know who you where sorry you came out last time we where there didnt you ? Mark and Russ your car looks hot and the times are great this will be one of the cars to watch i think
nice to meet you guys at the track Saturday!! all i can say is you guys in NSW have some bloody awsome race tracks, OP south was a blast and i can't wait to get on the whole track thursday.
i hope the weather is a bit better but we did have the track to ourselves so great for learning the lines.
yeah times were mainly in the low 46's but a few high 45's from Mark.
one weird thing happened, not sure but it seems the right rear tyre has a damaged side wall as it got really nervous on that corner late in the day after we rotated tyres. will find out thursday.
also the bloody track is hard on rims and exhaust!! lol i have never seen ripple strips like it!
cant wait to go back and looking to following some one around!!
cheers russ
cheers russ
Some how Russ i think they will be trying to follow you guys :3some: .
Nice work, i am hoping to get down there for a few practices in late June, might see you there?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
