  • Replies 1.9k
well, because gtrs can never be beaten of course!
ryan, do you laugh every time your car comes on boost?
Yer, its pritty cool a ! Maybe you should sell the gtr and i will help you with a very nice 25 set up. :D
Thanks guys :laugh:
Somethings wrong up top, ill find out exactly what quite soon. There was an incident during the build and i have a feeling that thats the reason its failed - which is good as its not my fault. The motor had been blowing white smoke since i picked it up, but only after a decent rev past 5000rpm, i thought it was the tune (or lack of) but now its pretty clear i was wrong, there was something wrong in there from when i got it
Dry sump fittings are on the engine but its still running a JUN pump (sump setup will be a scavenger setup to a tank in the boot that feeds back to the pickup, so it still uses the JUN pump but flow to the pump wont be an issue, so its slightly different to a normal dry sump :laugh: )
Dam those Lotuses are quick. I think on the day giant will be in the running with both on R compound tyres, and giants supper soft ones. Can't see how new slicks are similar to R compound though?
I went to Wakey on Sat for SAU track day, freezing day about 9c and windy and could not get there until after 2pm due to tow car Commy doing an alternator that morning and long story. Bit of mud on the tack and not good for grip as so cold tracktemps and rain that night and old tyres, bla bla bla managed a 1 min 5.49 a PB, and I was impressed until I put it in perspective with this pesky Lotus, and giant would do this with one flat tyre. Still doing more weight reduction and more power prior to the BIG day but budget does not allow for dog box yet, so will be running the stock gear box still. At least we will look good coming 3rd or 4th or 5th or..................
Dirtgarge thieving p...icks, I hate thieves and unfortunately trailers are hot property. Got a pic of what it looked like, never know small world and if unique it might show up one day at a track or on the road going somewhere.
Thanks guys :)
Dry sump fittings are on the engine but its still running a JUN pump (sump setup will be a scavenger setup to a tank in the boot that feeds back to the pickup, so it still uses the JUN pump but flow to the pump wont be an issue, so its slightly different to a normal dry sump :) )
I cannot believe im reading this....
Send it up if you want it done right Steveo....ill give you a student concession on fixing the build. I know of another smoky GTR engine build that had a little something go wrong in the top end too. Got two monster builds on at the moment that will take my time up but ring me if you need any assistance.
John, quick question - why do you keep posting photos of your zed lol :)
Steve - sucks mate, really does suck and I feel for ya mate :)
Here's a thought...how bout you enter club sprint class in the poopra?
Hi Mr Mackie
Don't try and tell us the Lotus is a cheap build :)
Super cool cars which I just love driving.
I heard a rumuor today that Peter Lucas is worried that he may not be fast enough ( only 11's on slicks on the weekend) and is thinking of getting Bargs or Luffy to drive the car at superlap :)
The GT3 Lotus did a 1.09 with Luffy at the wheel, and he thinks it may do a 1.08 (on slicks). That car would never be that fast on R compound :)
I think Peter should drive his car at superlap to give us a chance on the day.
Will be an awesome day. Looking forward to catching up :)
Edited by Bozman1
Hi John,
Well I'm sure our car was a lot cheaper than most of the car in superlap :)
I have no doubt that Peter and Tim would have got into the 1:09s if we put new slicks on. We were both running on well used tyres and new ones are worth 2 seconds easy. Which is why I am hoping that the new R tyres will see us on similar pace to last weekend. See you at Oran!
Hi John,
Our car was 30K...but then broke the world record for labour charges for a GTR street engine build (no, unfortunately we didn't build this one) So yes you car may be cheaper than ours...hehe
Edited by DiRTgarage
I wouldn't be relying on it, can't see how a used slick would have the same grip levels as a new R compound tyre.
Anyway, go-karts shouldn't be allowed at superlap, how are you supposed to compete against a 800kg car!!!! :D
It's amazing that a GT-R is exactly double that weight.
Anyhow, Teh GT-R can neva lose!!!!!!!!!!!!!!! :)
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
