  • Replies 1.9k
Here's some video that may/may not help those who have not drive Oran Park. (60mb)
http://idisk.mac.com/demackie-Public/OranPark.wmv
Awesome vid!
Much better footage than any youtube clips I've been looking at.
I guess I'll be studying this every night before the big day, never been to OP.
Looks like a tight little track, not much space to 'open up' the car.
Looks like im out.
Motor let go at Wakefield on Saturday.
Not fu(king happy Jan!!!!!!!
Sorry to hear about that buddy if you need a hand to sort it give me a call ,or drop past and see me ,we built a stocker with turbos ,injectors ,fuel pump,intercooler and computer it made 366kw on 21psi at the wheels last week with out cams or head work
We also built king 180s GTR he is also on skylines australia that made over 400kw at the wheels with 22psi but had cams head work and all the usual bolt on things his car is for sale on here very nice car
Ok guys some questions I have got lately regarding parts for their car like tow hooks and the sticker sheets for battery etc.
Hi Octane have bolt on universal tow hooks for $22 and they will have sticker sheets for sale on the day for $12.50
re tow hooks, there is a move away from steel hooks within CAMS to webbing straps instead because they are safer (ie less likely to puncture something in a crash). They also have the excellent benefit of not whacking your shin every time you walk around the front of the car.
Ours is just a trailer tie down strap (should be red) looped with about 10cm hanging out of the bumber and bolted to the reo bar where it meets the chassis. easy and effective but for the road car guys it would need a cut in the bumper about 10cm wide 2cm high to go through
I wouldn't be relying on it, can't see how a used slick would have the same grip levels as a new R compound tyre.
Smaller lighter cars dont get knocked around by less tyre grip as they dont use their tyres as much. I would expect an Elise, light and only moderate power, to be closer to its slick tyre time using a semi...then compared to the bigger, heavier and more powerful cars that would really need the tyre under them. But no doubt tyre grip is still tyre grip and all cars benefit from fresh grippy semis or full slicks
evil_ weevil I like putting my car in the face of GTR Jason every now and then in case he forgets.
I watched that Lotus in car vid and looks very stable and smooth.
My car cost me $6k about 7 years ago
See here for more. Motorsports section ZX build
Edited by Boosted Zed
Nice vid, cars looks very smooth and fun to drive.
IT would be sweet to get something like this happening here in Tassie, why does there have to be so much water that separates us from the rest of Oz :)
So many good cars still not ready for superlap. It is going to be a battle to get everybody to Oran. Lofty still waiting on parts, BEL still building engine (is it finished yet Uncle Dave) Penlington tuning his car to 600RWKW, Mackie trying to get his car to 600kg lol and the S2000 i am driving is still waiting for engine bits!!!
we are ready to smash Sydneykid in his ultra set-up car with all its development and technical wizardry. We set our car up in a weekend...lol...hope it doesnt show in our results. Its our first foray into corner racing so it will be good to learn some new sh1t.
Thats racing
As if you didnt know that already though :D
Yeah time is seriously against most of us. Ive got 8 tyres and only 2 wheels. The rest is somewhere in dispatch at BBS Germany. Anyone got 18x10.5 with -35 offset?
i may have a set ill check tomm.
Yeah the current rears are 18x12 -16 and fronts are 18x10.5 -10. Such a pain in the ass offset. As they are 3 peice its easy to change the width but things are moving slowely in Germany at BBS at the moment. Might end up running TE37's 18x10.5 +12 and a big boy spacers lol.
That's what I was contemplating running too. At the moment I'm just going 17x9 +22 with 30mm spacers, but going to the 18 is a consideration due to being able to run 285's. Pity the 18in RE's are so pricey...
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
