  • Replies 103
Well i kind of used a long thin flat head screw driver and pride them off... Its not an issue that i can't fix its just there is a very very fine spring around the Speedo pin and as that broke, there was no going back, the other guages i got working fine (fuel, temp, rpm)
that looks effin outstanding... cant wait!
You having your din guages done the same way? Urs and mine are gonne be exactly the same which is good - i can be assured they will be spot on.
bobbeh
Still, im in for paying a lil more if there are less people.
Anyway i have added the scans and inverted it to look white feel free to add your own logos or whatever you want for your design. Of course mine being an RB26 the redline is higher but as said before its just the shape and poistion of screw holes etc that is required you can have printed anything you like on yours.
Cheers
Yeah ill get a scan of the din guages up this weekend and hopefully get the whole thing sent off to Speed hut so they can start manufacturing them. Once i have all that done and dusted i will then negotiate price with them and see what we can do about having some price adjustment for less buyers.
Its getting there but we still really need some more peoples, spread the word to any forums you vist regarding Stageas as we need to keep the ball rolling! My mobile number is 0419366897 if anyone wants to contact me regarding this.
Cheers
im in for this 100% ive been chasing to get the dolphin gauge cluster but this way i can get the 300km/h white face blue lighting and the unicorn heads faded on the dials and although i own a 260rs i dont need the centre console gauges as i have removed mine for a double din screen but yeah get on board people
hey Daniel, thanks for the support i also want to go the 300kph setup but i am unsure if its possible to modify the standard cluster so the needle works correctly. I heard around somewhere that it was possible, but have had no hard evidence. Might be worth a looking into me's thinks.
UPDATED LIST
Signed up Names 12 down 13 to go. Almost half way tell all stagea groups and boards you visit to get in on this please
Mystag260
dmonic1
johnny8ball
Lil_bobby_260
Demoniak
D3RV
Oddy man
Pintaline
66yostagea
xmetal
Hum@nzee
260rsstagea
This sounds good - I got the Dolphin cluster priced at around $850 with 320 km/h speedo but thought it was a little too much. If there's a way to get the needle working properly with a 320 km/h speedo then I'm in.
  • 3 weeks later...
I'm just after kmh and mph in White. Speedo with nismo logo and the rev counter with a stagea body outline and stagea written on it! Think this is possible???
Yeah totally possible. I need to just get off my arse and get this stuff to speed hut so we can get people signed up on there.
Ill try and get it sorted this week, i will also have a go at some photo shop efforts this week so if there is any more suggestions for designs please let me know.
I found these skyline ones the other day which i recon look sick!
Hey guys, i have sent through all the scans and photos i can to Speed hut (finally sorry) so hopefully they will get back to me soon and we will have our Stagea guages put up on their site so we can all put our money ($1) where our mouths are. I also asked if there was a way we could reduce the number of people needed by adjusting the price.
I have attached a few pics of a few little photoshop logo inserts, so if you want to send me some ideas ill try and mock them up. i did attempt to make a kind of night time glow kind of mock up but it failed miserably.
Pm sent mate!!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
