could be a low reading dyno. how do other cars go on his dyno.
my old SR20 180 got 151 RWKW with just catback, filter and 15psi. And i had a 1J with same mods got 180RWKW. (EDIT:Both on Dyno dynamics in shootout mode on dyno days)
Well it seems to be one of the Better Workshops for performance cars and Dyno's in Townsville!! They have some pretty good cars in there at the moment!! It's been on there 3 Times now and all come up with 151 Kw's!!!
  • Replies 111
Yeah maybe are you sure
Maybe not
its not their Dyno
Mines been on theirs and pulled 195rwkws
Stockish r34 with some boost
Maybe not
its not their Dyno
Well if yours is a stockish R34 GTT and getting that result then mine should be pulling a little more then 151 being a GTR!
And if you say theres a better workshop i'm listening cause they cant diagnose my problem!! Not many other places to go in townsville! There are some places that i have heard some good and bad about!! Not gunna name them!! But ya pretty much know the performance shops in the Ville!
PMR33 and myself can vouch for how good The guys where you took your car to are
they were that good that when they failed we had to solve the problem ourselves
Well i'm not gunna waste my money for another workshop to tell me and go through the same problems and spend the same ammount of time to tell me exactly what i all ready know! So i'm sticking to the place it is! I have all ready got 8 Hrs of work done for free cause they were chopping and changing stuff on the car to see what it could be so i'm pretty happy actually with them and they do know there stuff there!!
Hey,
Well good luck with this workshop, having a tuned aftermarket ECU (MINES tuned for Japanese standards), 10psi boost, I made 154.4AWKW (pretty hot day but no excuses for the R33 GTR) with a 3inch cat back exhaust, compliance cat, compliance filter (airbox). I think the dump pipes were aftermarket.
However, I did high-flow cat, high flow panel filter, and got a PowerFC and tune and increased the boost to just over 14PSI, about 1bar, and I got 250RWKW.
So without engine management your not doing that bad, and be warned that dyno's do vary quite a bit, other people might get more but different dyno, different temperatures on the day....
I had the same problem when I first got my GTR, drove like an absolute pig. Went to Tilbrooks and came up with about 150rwkw's too. Ended up being a boost leak on the pipe leaving the intercooler. They simply tightened it up and it pulled 207kw's on a car which only has pods, 3 inch cat and exhaust, and running 15PSI with stock ECU and just for the record ran 12.4 in that state.
About 3 years later lost nearly all power once on the freeway, thought a turbine wheel had dropped into the exhaust - ended up being a collapsed cat as per a few previous posts. Put a new exhaust system on and got 218kw's! :D
Have you tried someone else ECU??
Na havent tried running someone else's Ecu!! Not really a fan of buying a 2nd Hand ecu and taking someone elses problems! Thinking of upgrading though to a Power FC But trying to find a New one at a reasonable price is pretty hard!!
mate i had a similar probblem, when i got my car it only made 140kw, the timing was out, fixed the timing and replaced the stock cat and got 222kw
thats with 3.5" exhaust and the restrictor out
Thanks for the Help Mate!
Timing was fine but they added an extra 5 Degrees on it and go an extra 20 Kw but this cam setting aint stock so its just overiding another problem that there!!
They wanna try another ECU but all they have there is haltech, wolf or something like that and some other brands that they can get for overpriced!!! Quoted me Some where between 1200 and 1400 for the Basic Power FC for a 32 GTR when i have seen them on ebay for 950!!!
Since you have a GTR you can actually BUY a PowerFC, it get it in Aus expect to be charged a lot maybe $1500 if off the shelf with warranty.
From Japan, anywhere between $950 and $980 is normal off the forum traders, if its not in stock it can take time, maybe 2-4 weeks but I've heard of some taking much longer.
If you have time look at sites like Greenline or keep watching ebay >_<
79,000kms huh? maybe more like 279,000
rigggggghhhhhht.
my money's on a worn out motor, gearbox, diffs, wheel bearings etc etc sapping what power is left.
Lol!! I know what my Car has mate!!
Thanks for the Advice Mate!
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
