Hey guys noticed the car playing up today.. anyhows it was idling like crap and had bout a litre of oil left (i filled it less than a month ago) Pulled apart all the cooler and intake piping and it is coated with oil...also when changing gears the car will spew white smoke out the back especially between 3 and 4th and also if I give it a rev while idling.. Sounds like seals on the turbo to me.. any other possibilities?? and if its seals whats a rebuild worth??
Sounds likely to be the turbo leaking oil. Check the oil breather lines on top of the rocker covers (or your catch can if you have one) to see if they're covered in oil too.
I reckon a turbo reco wouldn't be that expensive if you remove and replace it yourself before taking it to a workshop. Try maybe GCG for rebuild kits.
Your car spits white smoke? Odd, if the turbo isn't working properly (is it noisy?) i reckon you'd be getting black smoke as the ECU would send extra fuel trying to save the engine from misfiring. That happened to my mate's S15 when his intercooler piping had a massice hole- hardly any charge.
Have you pulled everything away from the turbo (piping etc.) to see what condition it's in?
Edited by R338OY
Don't rule out the engine being rooted. Do a compression test if you're stumped. Motor might have had it. Con rod bearings could be rooted. Piston rings could be too. I guess you'd know if your engine is dying :)
The work Hiace goes through 4 ltrs of oil in a couple weeks. Engine is on it's way out (400,000kms) and it has crappy compression and munches oil up.
I'm sick of changing the oil! Did it today again :cheers:
taking off the breather hoses and everything all the cooler pipes have been removed and the air intake piping.. amongst all the piping is enough oil to cover my fingers not just a lil but a thick black film
That can actually be normal. I don't have a catch can and when i ram my hand into the intake pipe, just where the breather hose goes into it, i come out with a layer all over my fingers.
Is it HEAPS of oil, or just a film?
i wouldnt think the engine is gone...but hey you never know..ive just pulkled off stuff like the bov and even the piping from the turbo and it is all covered in oil.. does anyone know what the numbers should be on the stock turbo..thgis doesnt look stock
sorry this is the r33 whoopps :) yeah think its def turbo pulling it off now and there is a lot of oil in the mouth of it..
other spots I found plenty of oil and I mean enough to leave a pool are bov piping, cooler piping, throttle body and piping and they piping from the turbo.. I did find a split hose on the rocker cover and have replaced this now as I just happened to have a spare in the same size..
also just thought id say I checked the turbo no real shaft play of anything so thats good :) at lkeast if worse comes to worst ill know its just oil seals..i've cleaned the pipes filled it with oil and put new plugs in it Ill drive it for the next few days and see how it goes..
is it worth while giving it a hard time or will everyday driving do the job?
I still believe you are yet to find the issue :)
If the motor has been damaged, you'll be getting a lot of blow-by and if all your plumbing is std that will all go into your intake, through the turbo and into the ic piping, etc.
When i cracked a piston ring land, the car sounded normal to my ears, ran and came on power normally. But as soon as my mechanic heard it idle up his driveway he knew straight away. My only indications were a small puddle of oil under the pod filter, after a track session, and it was harder to start in the mornings.
On the other hand it can be turbo seals.
So do a compression test and that would confirm the fault. If all 6 cylinders have similar figures, than your turbo seals are stuffed, if one cylinder is really lower (20+psi) than the others then its engine rebuild time.
hey guys my turbo i think, makes a noise like this RRREEEEEEEEEE lol, under load, hi revs..
i think its standard 32 but i could be wrong, still ceramic an all..
um and 15psi gets put threw it every day..
goodnight turbo?
fan belt stretchin under load?
how long left till turbo dies?
can i screw the engine if i keep it up?
sorry to hijack...
thanks chris
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
