Ok so about 1 hour ago I plugged my Ipod into the computer Itunes came up and for some annoying reason just restarted my Ipod to it's factory settings..
I hadn't backed it up because I was going to do that this weekend.
I have just lost about 30GIG worth of documents & photos on my Ipod. I really need these back because there are a lot of extremely important documents on there including your documents beloved SAU events!
I rang up a few Data recovery companies but they say it will be about $270 + GST
Does anyone have any other Ideas as to what I can do to get these documents back..
Please help :ermm:
https://www.sau.com.au/forums/topic/212076-data-recovery-help/
If there are any questionable photographs on it I'd be happy to have a look at it for you :ermm:
Have you looked around for data recovery software?
If you right click "my computer" and go to manage does your ipod come up as an extra drive on the computer?
If there are any questionable photographs on it I'd be happy to have a look at it for you :dry:
No they are not questionable photos!
They are every SAU event are more so!
Not really I don't want to touch it and f**k it up :ermm:
Not on this computer it doesn't I did on my co workers and it comes up but it's all the factory settings :ermm:
Whatever you do corinne, DO NOT load anything onto the iPod... If you do, you'll be overwriting your files permanently.
Have you tried this: http://www.recovermyfiles.com/ipod-recovery.php ??
Most likely its just the fat table thats been deleted so the files are still there, you just need software to recover it. If you write anything onto the ipod though it will overwrite your old stuff.
Dont you have another copy of the data? How is it possible to have a copy of the data on the ipod without having another copy on the computer? Doesnt it have to 'sync' with the computer to copy the data off? :confused:
Hehe.. let me know if either of those programs work. i'd be interested to know for the future.
By the way... I wouldnt recommend following barons advice about just plugging it into another computer. If itunes on the other PC tries to sync files to the device it will wipe your data for sure :ermm:
By the way... I wouldnt recommend following barons advice about just plugging it into another computer. If itunes on the other PC tries to sync files to the device it will wipe your data for sure :D
I know.
I wouldn't take Barons advice if he paid me, he's so dodgy.. :D
I don't have it synced to one computer. I do it manually so that I can steal everyone else's music.
sif. the baron knows what he's doing.
*note use the baron's advice at your own risk. any accidental permanent data loss is the sole responsibility of the numpty with the ipod. Baron corp and it's employees accept no liability for any such loss.
Haha seee :D
Told ya so!
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
