A mate from work just got back from a trip to Adelaide, where among other things he went for a drive through the Adelaide Hills on Easter Sunday.
He claims to have spotted a silver R35 GTR being filmed on a low flat bed truck, on a blocked off section of road. There were apprently Nissans parked all around, large group of asian men watching, large film crew and when he tried to approch he was not allowed past security.
He was unable to get a photo, but did save the exact location on his GPS, I'll post it up as soon as he lets me know.
I'm not sure how accurate his story is, I really want to know if anyone can cofirm it.
Did anyone else see/hear anyhing about this??
Well if they're gonna start selling the car in Australia they're gonna need some flash ads... I think it's plausible that it was shot in the Hills, it's got some wicked roads there. So will be interested to hear from anyone who can confirm this.
Kinda hard to believe but the Adelaide motor show is on very soon and apparently an R35 is going to be there.. nice coincidence
the Adelaide hills would be a great place to film a tricked out GTR ad.. I nice wide shot of it flexing along the mountainside roads :O
Should still be there(not saying were there is though....sort of like the pice attached...lol).....stopped and had a look at it 45 minutes ago.....even had a sit in.....why can my wife not look or feel that good!!!...lol
damn, didn't think to take photo's....even had a camera on me....sorry
Edited by Jetwreck
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
