please for the love of god.. dont have it running untill you replace those stock r32 turbos.. they will let go on you easily
haha i just wanna break engine with them, i am not gunna try to squeeze milk from a rock !! for the water return lines could i use something like this
http://www.gtfactory.jp/cms/e107_plugins/z...t=22&cat=11
Edited by stricnynel0s
Big power TT rb25 I had years ago. Photos are recent taken from the current owner, ignor the dust/dirt. New owner ditched AFM and went Djeto Power FC.
Oil and water lines were custom. Low mounted as it was more "stealth". Manifolds were factory cast GTR items that has the flange's cut off and re welded to suit the rb25 stud pattern.
Oversized forged pistons
Fully balanced
O ringed block
Major head work - Huge ports, a/m valves and springs ect ect
275 HKS cams
Custom cam gears
Greddy plenum
Q45 throttle body
100mm+ thick FMIC
GreddyBOV
Power FC
HKS 2530 turbos - Had them rebuilt using larger HKS 2535 wheels
HKS dumps
3inch front pipes
HKS 4inch super dragger exhaust
1000cc Sard injectors
300zx AFM (Might have been Q45, can't remeber)
Apexi pod filter
3/8 fuel lines
Malpassi fuel regulator
Wow,
Very nice engine bay - I take it the new owner's had it sitting in his dirty garage for years?
You didn't post up a power figure, or even better a dyno chart?? Would love to know what it made!
Cheers
Wow,
Cheers
Yeh, the current owner works in the mines or something and is never home, he is on the forums, no doubt he’ll come across this thread soon enough and be able to fill you in on all the little changes.
My under standing is, it hasn’t been driven in over 2 years, or close too and has just been sitting in the shed.
I don’t have dyno sheet, or wouldn’t know where to put my hands on one, sold that car way back in 03` or 04`.
There might be one in the zoom mag write up. I think it was number 33.
The hp figures however where 600rwhp on c16 with 1.8bar IIRC and 10.8 @ 128mph at Willowbank
also i had the same idea with the r32 turbos, now have 4 dead ones sitting in the shed.. they just didnt like being removed and put on a different car. i assume they need to be kept full of oil while off which i certainly didnt do. after fitting turbos, rebuilt the motor after bottom end noise, then the built motor was fine but turbos were shite...
so now i have fitted the turbos i initially wanted to after around 2k km's on noisy non-boosting half-blown r33 turbos. soooo much shaft play
but yeah lots of turbos in the shed looks cool? lol
is that the heater core hose ? and which one the top one or the bottom one ? since my car is lhd its all the way on the other side lol ohh well i will do it, its just a barb fitting from the turbo to an6 line at thet cross bracket ?
you might be better off doing same thing in the ottom radiator hose then, that might still be in the right spot? lol
thats worse lol !! i was thinking of returning the water to here http://www.gtfactory.jp/cms/e107_plugins/z...t=22&cat=11 ir maybe even the heatercore
if i use that air water seperator, i could do the two lines to the two intake nipples on it and the return nipple to the water nipple at the water neck on intake side
would it be more cost effective adapting the rb26 head to the rb25 block? how about the intercooler did you have to ditch your old one or did you customise the old one?
for example if i had twin turbos on an rb25 (lets say both can make 500hp combined power) stock displacement and all and if you put that side by side with an rb25 sporting a 2.8L kit and a 500hp turbo (single) which would be more responsive??????????
Assuming compression ratio is the same id put my money on the 2.8 with a single.
I would have thought the RB26 would be more resposive; larger displacement, better flowing head with larger cams, 6 throttle intake etc. Only down side i can see is the RB26 having a lower compression ratio. However surely a RB25 would still be slightly laggier with twins? Any one that has experienced both cars know?
I have a 420ish bhp RB25DETT in a RS13 which I built a few years ago. Very linear power delivery. Used R32 GTR standard turbos. Spools about 250rpm faster than my R32GTR and produces better power.
The only thing I prefer over the RB25 is the RB26's throttle response which is better but the 25 spooled earlier and generally felt more zippy which I attributed to the the NVCS and higher compression.
Change the pistons though, my number 1 piston broke up after two years/30,000 miles of being hammered.
I was thinking that the water return for the turbos could be routed around the front of the engine
to a fitting in the thermostat housing.
Has anyone tried this?
On second thought why wouldn't you just tee them together and use the exhisting return for the factory return.
  • 1 month later...
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Good time for a carbon roof
    • Not in any way aroused by any of those, except maybe the big AMGs. And that would break my never a Euro, ever, rule.
