  • Replies 66
HEY is anyone else having trouble doing direct deposit?
Bank sent me a letter saying they are the wrong details....
and i checked the details on the sheet to what i sent the money to and they are the same?
can i just pay on the day??
Yes...... yes i did.
The WRX Club have advised that they will sign up people with AASA Licenses on the day, if you complete the attached form and bring it along with you.
You'll also need to take the correct payment of $50 cash with you.
AASA_Club_Racing_License_Application.pdf
Mat - If you are having issus with payment, I suggest you email the event director at [email protected] - sorry, i cant help you with payment queries :(
Awesome. That email was what i needed. Cheers!
damn sam no good
this entry thing was a bit confusing..didnt know what the classes were and what not since ive never done a WRX day before.
sorted it though..associate under 3lt class here i come..
gah
probably ganna have to pull out
had no power last 2 days > no work on assignments done > due monday after wrx deca > no slidey action for me :D
I think you need a teaspoon of concrete. Harden up. haha.
Get into it son. You can make it! Not many DECA's this year.
hahaha yes you're right. doing my best and being a hermit this weekend to make time
man WRX are so slack...i emailed someone about my payment problems and still no reply? wtfs goin on with these people??
edit:
Entrants please note- I have made an error on the DECA entry form- I have put the incorrect bank account number for the club. Apologies for those making direct deposits.
The correct bank account details are:
Direct Deposit Details:
Account Name: Impreza WRX Club
BSB: 063 128
Account: 10369099
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
