hello hello ppl
well iam looking for sum info on a garrett to4e turbo of mine cause it does not say enything sep
garrett - a\r.50 so ill post up sum pic i got of it and can u let me no if it is a t042 or not
thanks
duncan
https://www.sau.com.au/forums/topic/212634-garrett-to4e/
Particularly if it's a new unit, I would be looking for some sort of build plate on the centre cartridge to identify its specifications.
I don't know that I'd have any issues with some casting imperfection on that comp cover though. It's either structurally flawed, or just a cosmetic thing. Pull the cover off and have a look inside. That will tell you whether to be worried about it or not.
I do think there needs to be a bit of re-orientation of the centre section so that the oil dump is facing downwards, and not upwards though.
Edited by Dale FZ1
https://www.sau.com.au/forums/topic/212634-garrett-to4e/#findComment-3756913
Went for a drive in a RB20 with a 700HP turbo on it the other day, i was unimpressed, never been in a car that actually came off of boost during a gear change and had to build up boost again.T04e's are very, very outdated man, i personally would be going something more modern, the lag that thing is going to have is a joke. Each to their own i suppose.
https://www.sau.com.au/forums/topic/212634-garrett-to4e/#findComment-3758860
Innovative made me a custom T04 with an O trim and the rest built almost identical to a 3582R I am making 480whp on my GTS4 at 1.4 bar with very little lag but my car has a Stagea Rb25det in it... on my Rb20det with this same turbo I was making just shy of 420 due to weak injectors and fuel peaks and it wasnt very laggy at all...
I would say get a hybrid built I payed 980 bucks plus shipping 2 years ago... and its ball bearing...
Edited by dwest
https://www.sau.com.au/forums/topic/212634-garrett-to4e/#findComment-3759081
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
