When accelerating in second gear form 60 to 100 sometimes theres a slight flat spot at the 80Km mark.
I have a 93 R33 manual Exhaust blow off valve.
I thought this may becauce of the exhaust and/or blow off valve
but I noticed this on another skyline I test drove a dead stock 95 r33 man.
I have only owned the car a couple of months and I am new to turbo cars. Is this normal? or do I have a fault?
https://www.sau.com.au/forums/topic/21267-flat-spot/
Probably just the way the stock fuel maps are setup in the ECU - if you wish to reduce it you will need a method by which you can adjust the air/fuel mixtures at particular revs... most use a S-AFC, piggy back ECU, or aftermarket ECU to do this. Hope that helps..
https://www.sau.com.au/forums/topic/21267-flat-spot/#findComment-448885
If you get a boost controller you will probably need some sort of fuel cut defender or you will get an even bigger flat spot. Do any electronic boost controllers have these? My Profec B doesn't, the car came with a HKS fuel cut defender as well and it works perfectly.
https://www.sau.com.au/forums/topic/21267-flat-spot/#findComment-456543
Guest Robo's
Mines got a bit of a flat spot too, sort of surges abit, its running way too rich as it backfires sometimes too. But sometimes it will pull all the way, but when it gets warmer (motor, airflow) it gets more consistant. First im going to try a cold air intake, as when i pop the bonnet and put my hand over the pod, it is very hot.
https://www.sau.com.au/forums/topic/21267-flat-spot/#findComment-467813
Yepp - this is very typical from the R33's.
You should see my dyno run !! Big dip in power when the ECU pulls timing and dumps fuel at about 4-5000 rpm :)
The S-AFC will help. It fools the ECU and shows the ECU a reduced air flow rate, therefore the ECU doesn't pull as much timing blah blah blah.
J
https://www.sau.com.au/forums/topic/21267-flat-spot/#findComment-467849
has happened with my rb30 as well hehehe
what it sounds like is mainly ur afm
im not too sure about the right setting for a rb25 , but with a rb30 , the air flow meter , needs to read a set ohmage of 382ohms , this measurement is taken from the 2 outer most pins on the afm , where the loom plug connects to it.
if its out it dummys info to the computer which is not correct and makes it run rich/lean etc , causes flatspots and hesitation etc etc etc.
also things like malpassi rising rate regulators can do it too , as boost hits , the fuel pressure rate rises at whatever rate the reg is (1.5:1) etc and that sudden fuel dump doesnt immediately get burnt , bit of a dull spot.
https://www.sau.com.au/forums/topic/21267-flat-spot/#findComment-468863
  • 3 weeks later...
Robo's Yours sounds exactly the same as mine.
Have you tried a smaller gap on your plugs yet?
Unfortunatly I live out in the country and I am the only one in town with a r33 gtst so I cant swap the air flow meter with someone.
Anyone else had this problem and solved it (cant afford SAFC).
https://www.sau.com.au/forums/topic/21267-flat-spot/#findComment-500311
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
