When accelerating in second gear form 60 to 100 sometimes theres a slight flat spot at the 80Km mark.
I have a 93 R33 manual Exhaust blow off valve.
I thought this may becauce of the exhaust and/or blow off valve
but I noticed this on another skyline I test drove a dead stock 95 r33 man.
I have only owned the car a couple of months and I am new to turbo cars. Is this normal? or do I have a fault?
https://www.sau.com.au/forums/topic/21267-flat-spot/
Probably just the way the stock fuel maps are setup in the ECU - if you wish to reduce it you will need a method by which you can adjust the air/fuel mixtures at particular revs... most use a S-AFC, piggy back ECU, or aftermarket ECU to do this. Hope that helps..
https://www.sau.com.au/forums/topic/21267-flat-spot/#findComment-448885
If you get a boost controller you will probably need some sort of fuel cut defender or you will get an even bigger flat spot. Do any electronic boost controllers have these? My Profec B doesn't, the car came with a HKS fuel cut defender as well and it works perfectly.
https://www.sau.com.au/forums/topic/21267-flat-spot/#findComment-456543
Guest Robo's
Mines got a bit of a flat spot too, sort of surges abit, its running way too rich as it backfires sometimes too. But sometimes it will pull all the way, but when it gets warmer (motor, airflow) it gets more consistant. First im going to try a cold air intake, as when i pop the bonnet and put my hand over the pod, it is very hot.
https://www.sau.com.au/forums/topic/21267-flat-spot/#findComment-467813
Yepp - this is very typical from the R33's.
You should see my dyno run !! Big dip in power when the ECU pulls timing and dumps fuel at about 4-5000 rpm :)
The S-AFC will help. It fools the ECU and shows the ECU a reduced air flow rate, therefore the ECU doesn't pull as much timing blah blah blah.
J
https://www.sau.com.au/forums/topic/21267-flat-spot/#findComment-467849
has happened with my rb30 as well hehehe
what it sounds like is mainly ur afm
im not too sure about the right setting for a rb25 , but with a rb30 , the air flow meter , needs to read a set ohmage of 382ohms , this measurement is taken from the 2 outer most pins on the afm , where the loom plug connects to it.
if its out it dummys info to the computer which is not correct and makes it run rich/lean etc , causes flatspots and hesitation etc etc etc.
also things like malpassi rising rate regulators can do it too , as boost hits , the fuel pressure rate rises at whatever rate the reg is (1.5:1) etc and that sudden fuel dump doesnt immediately get burnt , bit of a dull spot.
https://www.sau.com.au/forums/topic/21267-flat-spot/#findComment-468863
  • 3 weeks later...
Robo's Yours sounds exactly the same as mine.
Have you tried a smaller gap on your plugs yet?
Unfortunatly I live out in the country and I am the only one in town with a r33 gtst so I cant swap the air flow meter with someone.
Anyone else had this problem and solved it (cant afford SAFC).
https://www.sau.com.au/forums/topic/21267-flat-spot/#findComment-500311
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
