Okay guys, heres the deal, yesterday was tuning day for me and my freshly built rb25/26 hybrid. Well we had serious problems getting down there non car related it was a long day...
I'll cut to the chase, car started out AMAZING, 500 rpm increment pulls with the microtech lt12s slowly but surely adding fuel with 14psi through the gt35r. We were making 300ftlbs at 3000 rpm.... We made 387rwhp and 345 ft lbs at 5500 rpm loads at 14 psi. Never got to make a full sweep yet... At that point we were running out of fuel. The nismo FPR cant handle the dual pumps or something, and is not raising its pressure properly. So I ran down to Jegs and got an aeromotive. Hooked it in cant get the base FP down any lower than 55-56 with vac, it just wont go any lower... So tuning was compensated for that.
Now heres were it gets weird. Our numbers started falling off, yet the motor sounds extremely strong, no different then it was before. So after a few ramps at 4000 we are only at 200 is ft lbs now about a 1/3rd or a bit less than before... we decided to check the plugs. They were fine, A/F's are 11.1-11.3 the entire time, with little timing seeing around 16-17 degrees the coming back down as boost was added which was now around 16-18 psi (we didn't touch the MBC). Super super conservative tune, but no power now? So we do a compression check and leak down test cylinders are all 150+ish, leak down test is 95-100% across the board.....
We are coming to the conclusion the valves are leaking under pressure. Or they just arnt opening enough. Some of my lifers were squishy.. right after we shut it off and some are rock hard how they should be and others were soft. Theres no lifter tap however. You guys think the lifters are preventing my valves from getting proper lift thus the drop in HP? Or it could be the springs being weak and leaking off? I'm only at 8.5mm lift and 264in-268ex duration...
Anyone ever seen a similar problem such as this? They car is drivable, it sounds like a ****ing animal, holy **** the added displacement and modifications makes it sound so scary.... I've got footage and **** I need a buddy to send it to me so I can show some of the pulls. But right now shes a total dog. It idles great, No boost leaks nothing of that, we checked everything....
Also the injectors are re flowed to 740cc's they are from a reputable company who has been proven and known for their injectors.
lets hear some other opinions on the matter... I'd really like to know what the deal is. I'm leaning towards a valve related issue.
https://www.sau.com.au/forums/topic/212699-rb27-tunning-problems-and-issues/
what pressure were you running with the nismo fpr? how was the tune "compensated"? wouldn't you need a retune for a different base pressure.
how were the injectors re-flowed? i know you said they were done by a reputable company and thats great if you trust them, but i was of the assumption that they flow what they flow from the factory. correct me if i'm wrong.
nah you can get injectors highflowed. but some companys dont like this idea, they say it doesnt give as good of a spray pattern as a injector already built for XXX about of CC.
personally i havnt had personal dealings with highflow injectors...so i cant comment if they are good or bad.
My 20 cents;
Compression and leak down tests would show up leaking valves due to insufficient valve spring seat pressure. Although it won't show up oil pressure leak down of the followers. But leaking followers usually means rattling on start up, which you report isn't there. So I doubt it's a valve issue.
Did you check (with a timing light) that the ignition timing actually agrees with what you have mapped?
Have you tried dropping the exhaust? We had a flexible joint fail on a car on the dyno recently and it blocked the exhaust flow. All the numbers (A/F ratio, knock etc) looked OK, but it just dropped power by 25%. I tried the usual drop the exhaust at the first joint and it picked up the lost power straight away, some examination with a torch showed up the restricted exhaust flow.
You may also want to check the inlet pipework for a similar collapsing problem, although that generally shows up in a loss of boost.
Cheers
Gary
My 20 cents;
Cheers
Gary
Gary,
I see what your saying with the valves being shown leaking in a leakdown/compression check. However wouldnt they just get pushed up and closed from the cylinder pressure and not leak? I'm thinking when the boost is coming on. On the intake side port when the valves should be closed the boost pressure in the plenum runners is forcing them to open due to weak springs?
I have a reason the springs could be possible weak. When I rebuilt a few of the hydro lifters that were squishy before reinstalling them. However I re-installed the bleeder valve upside down, causing the lifter to be to tall and incompressible. This made the valves leak. So I had to remove them all and install lifters I had laying around from another motor. But the motor was cranked with these lifters installed wrong a hundred or so times... now I'm not sure what type of lift I would have been putting on these springs but I feel like I might have fatigued them. It seems so strange that the power we were making went away after our best pull when the numbers were starting to get up there. Possibly just finishing my springs off?
After we ran into this hp issue the boost was actually higher than it was before even though the MBC wasn't touched. (from 14 psi to 17-18psi)
Also 3000rpm had the same hp/tq basically as 4500rpm.... There were no gains like there was before (172hp/300ftlbs@3000 to 282hp/330ftlbs@4500)
I can check my exhaust, its just pretty much a straight pipe. 2 mufflers and one connection. Its possible the gasket for that broke and is hanging in the pipe? I'm doubting it but I know you are saying. I've seen a bad cat absolutely turn a truck into a dog due to being clogged just killing the power.
thanks, any more ideas insight would be greatly appreciated.
-Cory
****UPDATE!!****
I found a big boost leak after I was working on my car... fixed it took the car out for a drive and it felt a LOT better however...
Well it appears as if my ***-Dyno is off by over 50%. We got back on the dyno today, only to see my issue did not go away. The boost leak fixed spool times and response, but didn't fix ANY numbers...
We are making 200ft-lbs at 2000 and at 4000 with 14 psi. Fuel pressure is all straightened out now. Holding 45psi vac off at idle. Didn't change at all day. The car just has no balls. Dont get me wrong, its not slow, but its no where near what it should be.
Everything is basically perfect. Air intake temps, water temps, a/f ratio (11.1-11.3 at WOT), timing is spot on as well, plugs are great, good equal burn pattern and no missing..., muffler is not clogged by any means.
I drove down with my buddy who owns and EVO 8, my car is basically as fast as his bolt on EVO.... to give you an idea, but its not making numbers of what it should be.
We really are thinking that its something with the valves/lifters/springs.
Springs possibly weak and when boosting begins they start leaking at the intake ports that are supposed to be closed. (so the back of the closed valve stem is being pressed down by the 14-15 psi in the plenum)... even if it is just a little bit, its enough...
Or I have some bad lifters, but I'm doubting that since we have no lifter tick. Even this morning I turned my car on it was 32 degrees outside and no tick....
opinions would be greatly appreciated. As nice as it is to drive my car now, I feel like I have wasted xx,xxx dollars just to make it as fast as it was before...
The head I'm using is not my old head but rather someone elses...so I'll I know about it is that the valves hold cylinder pressure... but I don't know about boost...
I'd really appreciate ideas, I'm getting very stumped...
-Cory
The Tomei type A springs will be good.Up to 9.0mm lift and will rev to 8500rpm.
Im not saying this will fix your problem,couldnt hurt though considering you will eventually be putting big power through it.
Yeah it is a good idea, how do you know which washers to pick?
http://www.tomei-p.co.jp/_2003web-catalogue/efr_index.html
they are not bolts, they are allen keys that are weak as piss, you cant do them up without stripping them.
I have the exact same cam gear and i replaced 4 of them with 10mm bolts, which so fit in the grooves.
I am going to pull my cover off and check mine to make sure they have not moved.
its a cheap cam gear so this is what you get i spose.
But doesnt it feel good to know that you have found the problem!?
FYI: My Tomei valve springs arrived and they did not have the washers with them.
It feels amazing.
thanks for the tip Guilt Toy, I'll go look for some new hardware to tighten this gear better.
I cant wait to get back on the dyno to lay down so good numbers hopefully.
This car makes me wise and wiser with every issue. :blink:
Hence people should just mod the factory cam gear and make that adjustable
Never fails, cheap as chips :/
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
