Ok I've stripped my R32 Rb20 Front Halfcut.... any there are heaps of parts i don't need.
i'll list all the main parts, and as per forum rules... i will post a price, if you are unhappy with my prices, please keep in mind all these prices are negotiable!
~ Prefer Pickup, parts located North Eastern Suburbs of Melbourne
~ Contact Mark on 0408 569 685
______________________________
INTERIOR
Centre Dash piece (good condition, its the big dash bit that goes in the middle where the radio etc is) - $15
Accelerator pedal and bracket - $10
Brake Pedal, bracket and sensor switch - $15
Under dash front intrusion bar (very good condition) - $5
AirCon core box (very good condition) - $20
Under dash fan box (very good condition) - $15
Glove box (quite good condition, small plastic mount snapped, but easily repaired) - $15
SUSPENSION AND STEERING PARTS
Std Shocks and Springs ~ front pair only (very good condition, not leaking) - $35
Std Castor rods ~ pair (excellent condition, bushes look brand new) - $45
Std 5 stud Hubs and Rotors ~ front pair (hubs and disk rotors in great condition) - $70
Std Upper control arms ~ front pair (very good condition, perfect if yours are bent from accident) - $45
Std Sway bar (very good condition) - $25
ENGINE BAY PARTS
Carbon canister (very good condition) - $15 Sold pending payment
Clutch Fan (quite good condition) - $15
Solid Brake lines ~ front pair (very good condition) - $10
Windscreen Wiper Arms ~ complete (good condition, but need a coat of paint) - $10
Windscreen Wiper Motor - (very good condition) - $15
Bonnet release cable and latch - (very good condition) - $15
Bonnet hinges ~ pair (good condition) - $5
AirCon reciever dryer and condenser (very good condition) - $20
____________________________________________________________
if you need something that isnt listed here, ask me anyway as i may still have it
Edited by Ruffels
Hi mate,
is this the whole thing or just the centre console surround (the bit that go around radio and down to gear boot)
if this is the surround part, I'll take it, can u post it to 2250 NSW?
How much all up?
Cheers
Edited by subie
Hey mate, do you have a drivers aApillar interior trim? (with no holes(i know its a big ask))
If so could you please PM me with price and i will pick up.
Thanks!
Femno, unfortunatly they cut the car at the a pillar, so i don't have those trims, sorry!
Rad33, all main vents are either missing or damaged, however i have circular drivers side vent, and the small vents that blow at the windscreen and at the side windows
do you have all the demister airvents for the top dash?
are they warped/cracked from the sun?
Ill take them :P
edit; will also take the door hinges if the rubber is perfect on them.
Can you PM me some pics?
What suburb are the parts located?
ALL PM's Replied!
________________
sorry mate, forgot to mention that i'm keeping all engine and gearbox components for an engine swap into another car... just selling bits i don't need
once again i appologize about the confusion
-Mark
how much for afm? pm me
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
