Thanks for the support guys.
I sell stuff on this forum. when i do, i make sure i describe and price it correctly. i do everything i can to help out the person that buys my stuff. Its a great way to support the forum community. then things like this happen and it stuffs it up for everyone... :(
It appears that the pump may have locked up and the crank has spun a bit further cracking the drive ring and sending cracks everywhere...
here's some pics...
what a tosser, you can clearly see its f**ked from those photo's. gave himself a bad name, all over $300. pffftt send jun an email, they are really helpful, maybe they could sell you a new drive?
Edited by sic200
Sorry i haven't been on
Emails dont get sent to my email address, as im using the girlfriends account
I also don't check the nissan forums much .. seeing as i own a toyota
Ron's getting every dollar back, don't jump to conclusions kids, i just haven't been e-stalking this site 24/7 :nyaanyaa:
It seems i may have offended you.....for which i am truly sorry
hope you hold No hard feelings.
Alfie
No problems, dodgy kents are aplenty, especially since 99% of sales dont require you to even meet in person/talk to someone over the phone, too easy to be 'anonymous'
I have sold a few other things here from my (ex) 25 build, a GT35R, ARP studs, forged pistons etc, and all those people have been more than happy with their gear.
But yeah, apology accepted. :(:nyaanyaa:
Edited by Sammy
Sorry man.
You are a very rare breed for being so honest and in returning the money even when you didn't have to.
maximum respect.
rob
But yeah, apology accepted. :blush::whistling:
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
